Charge 3 isn't registering my running time
It doesn’t register my running time, all other info, ie distance, calories & so on, but not how long I’ve been running? Have reset twice, but still not? Any info would be great.
Thanks 🤞🤞
4 REPLIES 4
It's great to see you here, @Nikkchap26.
Thanks for troubleshooting this exercise issue. Can you please tell me how did you record your exercise? Did you select it directly from the device or did you use SmartTrack? In the meantime, you can check the help article: How do I track my workouts with my Fitbit device?.
I hope to hear from you soon. 🙂
Hi, I selected it straight from the device...
Thanks for the update, @Nikkchap26.
At the moment of ending the activity, are you making sure to finish it from the device? Can you provide me with some screenshots of this workout?.
I will catch you later. 🙂
Hi , not sure what you need?? ... I do stop the Fitbit on my wrist when I
finish running... this is a pic of my results on my IPad...
Thanks Nikki
