09-07-2021
06:47
09:12
CindyMFitbit
09-07-2021
06:47
09:12
CindyMFitbit
I have issue with my Charge 3 watch, when pressing the side button, it vibrate continously for as long as you have your finger on the button, heavy vibration and then comes up with 001 on the screen. Resetting won't resolve the issue and really concern about continous vibration when pressing the side button.
Anyone experiencing similar issue and have a fix, please share your tips
Moderator Edit: Clarified subject and label
09-07-2021 09:19 - edited 09-07-2021 09:19
@Fotunba Welcome! It's great to see you around.
Thanks for the details shared on your post and for troubleshooting the issue prior posting.
I'd like to confirm if you tried to restart the Charge 3 using the instructions listed here. Also let's try the long restart by performing the steps below:
On a side note, I've moved your post to this thread so we can keep our forums organized.
Hope this helps.
Best Answer09-08-2021 07:19
09-08-2021 07:19
@CindyMFitbitI have tried this option (which is full of internet) before posting my question, my issue is not really about error 001, yes it cme up but the main issue is continous vibration anytime i pressed the side button. The vibration won't stop until i release my hand after whi the error 001 will show up. If I press the side button while the watch is charging, the vibration continues then error disapeared but the moment I disconnect the charge and before putting the chrger back on, the error message re-appeared and the cycle continue.
Best Answer09-08-2021 07:52
09-08-2021 07:52
@Fotunba Thanks for your reply.
I appreciate for confirming that you have followed the recommended tips for this issue with the Charge 3 and since the issue has persisted, my best recommendation is that you please reach out to our Support Team for further assistance.
You can click here to get connected. Also, take into consideration that you can contact them through chat or over the phone, but phone wait times are longer than normal, so I recommend initiating a chat.
Also, please make sure to provide a brief explanation of the inconvenience and mention the troubleshooting steps you've followed prior to posting.
See you around.
Best Answer08-15-2022 05:32
08-15-2022 05:32
Did you get a resolution to this? I'm having the same issue, restart won't work. They've offered me 35% off a new one as mine is out of warranty but I'm hoping to fix it.
Best Answer08-15-2022 23:05
08-15-2022 23:05
Hi there,
I to have this problem. If this can be fixt, this would be great and otherwise, how or where did you come to the point that they offered you a discount?
Kind regards
Best Answer08-18-2022 13:48
08-18-2022 13:48
I spoke to them on webchat. I just got a discount because mine is out of warranty
