08-04-2019
07:51
10:55
08-04-2019
07:51
10:55
My charge 3 has started losing time over the last 24 hours. First it was by about 15 minutes. Rebooted my phone and fitbit and it came back. Now it is down by 5 minutes. It wont sync even when i refresh sync and when i refresh the app is says no device found.
08-04-2019 19:33
08-04-2019 21:24
08-04-2019 21:24
Best Answer08-05-2019 00:19
08-05-2019 00:19
I'm having the same problem. Noticed on Saturday that the time was wrong on my Charge 3 the app after trying to sync stated No Device. I restarted the charge 3 and the app. This did not work at first, but eventually managed to get a sync. Woke this morning and the time is again out, this time by 2 hours. Unable to sync, app states No Device. Charge 3 has work great for last 10 months, but this is becoming a problem, as I can't rely on the time displayed. I have a Sony Xperia XZ1.
08-05-2019 06:14
08-05-2019 06:14
The problem is the non sync issue.
08-05-2019 06:36
08-05-2019 06:36
Best Answer08-05-2019 06:41
08-05-2019 06:41
Best Answer08-05-2019 06:43
08-05-2019 06:43
The ability to sync really has nothing to do with settings. But usually has to do with a software/hardware issue.
First step is to remove the tracker from the phones Bluetooth.
Then I would restart it power off the phone.
Restart tracker.
Clear the phones cache
08-05-2019 07:06
08-05-2019 07:06
Best Answer08-05-2019 14:28
08-05-2019 14:28
I contacted Customer Services and after trying a number of different restarts, and different devices, they gave up and are sending a replacement Charge 3.
Best Answer08-05-2019 16:50
08-05-2019 16:50
Best Answer08-06-2019 07:33
08-06-2019 07:33
Same issue. App reports 'no device found' and tracker will say 'unable to connect to phone' when trying to use GPS.
I've found that if I take the tracker off for a few minutes it will start to sync again, I've just put my tracker back on and 'no device found' when syncing. Took it off and put it on charging cradle and it syncs. This is not a solution as the phone and app will not connect to allow the use of the GPS when wearing it.
I've also found the 'no device found' issue happens when the tracker gets warm to body temp and will only sync after removing for 5-10 minutes.
I've had one tracker replaced yesterday, only for the replacement to develop the same issue today. Being able to connect and sync only on the cradle is ludicrous and prevents the tracker from being used with GPS whilst exercising.
Best Answer03-28-2020 10:52
03-28-2020 10:52
Same I have a Samsung s9 was working fine . Have now removed and reinstalled changed password still won't work still looses time now won't sinc won't correct time . Fit bit using exuse on help line that they are slow due to covid. May my fit bit must have caught the virus. Getting sick of fit bit. . I have read so many complaints of the same nature none is seem to get them to sing to keep time. Sorry hope we both can get this problem fixed. These watches are not cheap cheers to all please help
Best Answer05-23-2020 01:11
05-23-2020 01:11
So how do we fix it?
Best Answer05-23-2020 05:20
05-23-2020 05:20
05-24-2020 12:58
05-24-2020 12:58
Sigh. Mine is 1.6 years old and only started having this issue 3 days ago.
