Charge 3: new food log resetting calories
When I try to add a new custom food, I add all the nutrition information and when it is saved the calories reset to 0.
5 REPLIES 5
That is a known problem to be fixed in next IOS app 3.19
And if I try to edit the custom food to try to get the calorie information corrected, it saves but then it also goes back to 0. Anyone that could help on how to fix this?
I see. Thanks for your quick reply. When is the new update coming?
You can still add food through the web.
BTW you are not doing this through the Charge 3
Thanks for replying.
I will add through the web then for now.
