Charge 3 not charging properly and it drains the battery quickly
Following up the draining 10% an hour problem, the fitbit no longer charges properly.
It shows 100%, all happy. Put it on for 1 minute, drops to 1% then 0...dies.
I haven't gone over this cycle over 10 times, each time letting it charge for 30 minutes to an hour.
Sometimes I would reset it when it's done at 100%, it may show just 1% again for a bit, then 100%.
I reset it and it shows 1%. It just bounces between 100% and 1%.
No, if the contacts are dirty, it wouldn't be charging at all.
3 REPLIES 3
Hello @Piggy. It's great to see you around.
Thank you very much for the detailed information and I also appreciate the troubleshooting steps you've followed. While you have restarted or reset your Fitbit device, I would recommend performing a long restart. To do the long restart, please follow these steps:
  1. Connect the device to the charging cable.
  2. While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  3. The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
  4. The device turns off.
  5. The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  6. Remove the device from the charging cable. The device shuts down.
  7. Important: Plug the device into the charging cable again.
In addition, I recommend taking a look at the rest of the tips provided in this link, to see if these tips could help:
Why isn't my Fitbit device's battery charging?
Hope this helps.
Wilson M. | Community Moderator, Fitbit.
Looks like my device is regressing.....now it only gives me 6 vibes, off charger, on charger, 6 vibes again
It used to go to 7, show 0%, charges to 1% then jumps to 100%
@Piggy Thank you for the information.
If you notice the inconvenience persists, then I recommend reaching to our Support Team for further assistance. You can contact them through chat or over the phone. Click here to get connected.
Make sure to explain the inconvenience and the troubleshooting steps you've followed, this way our Support Team can assist you from there.
See you around.
