11-05-2018
17:10
15:03
11-05-2018
17:10
15:03
Since upgrading to Charge 3 I no longer get text messages from my I phone to the Charge 3
11-06-2018 04:33
11-06-2018 04:33
Welcome on board @mchalej! If your Charge 3 is still not receiving Notifications, please try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
11-06-2018 04:33
11-06-2018 04:33
11-06-2018 09:47
11-06-2018 09:47
Thank you for the help
Best Answer12-26-2018 06:37
12-26-2018 06:37
I followed these steps..still not getting messages. "Show in history" is not an option in my notifications...I don't know if that's the issue??
12-31-2018 11:25 - edited 12-31-2018 11:29
Hey there @sallyq3, thanks for jumping in here! Can you please send me a screen shot of the options you've available on the Notification settings on your iOS phone? See my image below, your options should look like mine:
Looking forward to your response!
01-04-2019
20:06
10:08
JuanJoFitbit
01-04-2019
20:06
10:08
JuanJoFitbit
My Fitbit was not receiving notifications for my text messages on my iPhone. I went to my notification setting on my phone and went to the message app. I went to repeat alerts and shows once. And it worked out from there.
I have a Charge 3 and an iPhone 8 Plus.
Moderator edit: merged reply
01-07-2019 04:53
01-07-2019 04:53
I filed a claim and receive notification via email to return my charge3. However, it started working again So I kept it MISTAKE!!
Again not working, can’t receive text messages and I’ve tried all of the instructions Fitbit has posted.
I’m really disappointed with the charge3 and wished I had just returned it .
it stopped working a week after I received it.
I would like to return if possible or exchange.
03-09-2019 16:53
03-09-2019 16:53
I have set my iPhone up to my Fitbit charge 3 and I cannot get messages to the fitbit. It shows in the app that I have the notifications turned on for calls and text but it’s not coming through. Any thoughts?
03-16-2019 10:59
03-16-2019 10:59
Thank you, this worked for me 😊
Best Answer03-17-2019 12:21
03-17-2019 12:21
I can't see how to start a new question, so I'm going to hook on to yours and hope I see a reply. I got my Charge 3 for a Christmas gift-- but for a lot a reasons just today had a chance to set up. It is not receiving text notifications even though all my settings on my phone are correct. I've gone through the whole sequence recommended-- TWICE. Still nothing, Is this a problem with my Fitbit?
03-17-2019 12:40
03-17-2019 12:40
Best Answer03-17-2019 14:56
03-17-2019 14:56
03-20-2019 04:05
03-20-2019 04:05
I followed the advice given on this forum, and like many others...I still was only getting alerts for calls - not messages. Then I found a Fitbit help article that gave me my solution:
I checked my phone and realized my "Show as Banners" was off. Once I turned it on...I started getting alerts for my text messages on my Charge 3 too.
03-22-2019 07:19 - edited 03-22-2019 07:21
Hello guys, sorry for the late response.
Welcome on board @aparker0413! Thanks for making sure you have notifications turned on for calls and texts. However, I was wondering if you've checked what was recommended in this post? My friend @LindaPB has also shared here what worked for her, take a look at her response.
Hello @Poohpie! I'm glad to hear that the steps provided worked for you. Also, thanks for helping out in this thread. ![]()
It's nice to have a new member around, welcome @Babygirl57! I appreciate you've taken the time to follow all the tips and recommendations provided. Also, thanks for making sure your phone's settings are set correctly.
Since your device is still not receiving Notifications, please try the following:
Give this a shot and let us know the outcome!
03-24-2019 19:58
03-24-2019 19:58
This didn’t work
Best Answer03-31-2019 17:52
03-31-2019 17:52
I feel the same way. I wish I had of kept my charge 2. I never had pRobles like I do now with my charge 3.
03-31-2019 22:43
03-31-2019 22:43
Thank you this really helped though I have an android it still worked the same way
Best Answer04-04-2019 11:37 - edited 04-04-2019 11:39
Hello there @Petie and @Redpassion! Sorry for the late response.
Thanks for following the recommendations I've provided above. I suggest to try the steps provided at: My Fitbit device isn't receiving notifications from my phone.
If you are using more than one device (iOS and Android) to sync your Charge 3, note that If your phone is managing multiple Bluetooth connections simultaneously:
These interruptions are typically caused by operating system and Bluetooth limitations. It's also possible that an app on your phone is causing the issue.
If you have an Android phone, try these steps:
The API used in these apps makes it difficult for Fitbit to communicate reliably with your phone. Ford provides a list of apps but note that other companies may use the API as well.
Welcome to the Fitbit Community @littlebitt! I'm glad to hear the steps worked for you.
Let me know if the steps work, I'll be around.
Best Answer05-31-2019 09:52
05-31-2019 09:52
hi -- finally got it to work. I told my iPhone to forget the Charge 3 -- then TURNED OFF THE iPHONE and turned it back on, before proceeding with the instructions below
thanks all!
- Go to the Bluetooth settings on your phone and check if your tracker is on the list of paired devices. If it is, tap on it and select Forget this Device.
- Open the Fitbit app
- Tap on Account > Charge 3 > Notifications
- When a pop-up with a "Bluetooth Pairing Required" message, tap on Set Up and continue.
- A new "Bluetooth Pairing Request" will appear, tap on Pair to continue
- Once in the Notifications menu, enable the ones you'd like to receive.
- Go to your phone Settings > Notifications > Fitbit and make sure the following is enabled:
- Allow Notifications
- Show on Lock Screen
- Show in History/Notification Center
- Show in Banners
06-01-2019 10:22
06-01-2019 10:22
Welcome on board @sharonella! We're glad to hear that the steps provided above solved the notification issue you were experiencing. Thanks for sharing the outcome my friend! ![]()
Let us know if there's anything else we may do to assist you with, it'll be a pleasure.
