11-05-2018
17:10
15:03
11-05-2018
17:10
15:03
Since upgrading to Charge 3 I no longer get text messages from my I phone to the Charge 3
03-30-2020 08:14
03-30-2020 08:14
This worked for me after I was totally frustrated with my Charge 3 not showing texts from my iPhone. The huge step YOU MUST DO is Forget This Device, then re-pair it with your phone. You must go through the steps, making sure the message pops up that the device wants to pair with your phone. If that doesn't happen, then it won't work.
Best Answer04-13-2020 17:52
04-13-2020 17:52
Showing previews when unlocked did solve the problem for me...but it defeats the purpose of having the message previews off. Still, that makes it seem more like an iOS thing than a Fitbit thing, so I guess for now I will turn message previews on...I have nothing to hide from anyone and the "off" setting is just a carry-over from years ago.
Best Answer04-18-2020 03:28
04-18-2020 03:28
Hi unfortunately they will tell you to go though the settings on your phone and Fitbit app but the charge 3 won’t get text messages I’ve done everything they asked more times than i can remember it happened from the an iPhone update a while back and Fitbit hasn’t caught up yet and dealt with the problem
Best Answer04-27-2020 10:15
04-27-2020 10:15
Hi All,
Same problem with no text to email, however when following the posted instructions, when I'm in the Fitbit app, select Notifications, and Set Up when the popup appears.....nothing happens. So I can't proceed with the instructions. I've tried turning my phone off and on and now my phone is disconnected from the fitbit. Any ideas?
Best Answer04-28-2020 04:22
04-28-2020 04:22
I have tried every thing and though it has been like this now for over a year. I feel as though I need to buy another one in order to get notifications on my FitBit. This shouldn't be the case. I can get app notifications, still unable to get texts messages. Is it an iPhone issue or FitBit?
Best Answer04-30-2020 09:21
04-30-2020 09:21
I’m having same issue and it’s so frustrating! I have paired and unpaired the device. Deleted and redownloaded snd checked all notification settings. No texts or call notifications no matter what I do.
Best Answer04-30-2020 10:21
04-30-2020 10:21
Best Answer04-30-2020 11:29
04-30-2020 11:29
Hi everyone this is exactly the problem I had about 5 months ago and it’s a pain... but I got it working by repeatedly doing
Basically I forgot connection to Bluetooth and reconnected eventually!
I hard reset my iPhone several times to pair the HR with my phone again... took several attempts and then hard reset the HR in the watch itself by going into settings on the watch so as to avoid wiping the data on it or the app. I also went into notifications on my iPhone and set as per attached image. It took a lot of attempts and swearing but I eventually got it to work. I also went into Fitbit app and made sure I’d got latest version via App Store
Best Answer04-30-2020 11:34
04-30-2020 11:34
Also
In notifications on your iPhone you need preview always set
hope this helps everyone... do t give up
Best Answer04-30-2020 12:54
04-30-2020 12:54
Best Answer04-30-2020 17:13 - last edited on 04-30-2020 19:17 by LiliyaFitbit
I got the texts working by allowing “preview” message under notifications but STILL not getting call notifications. For $100+ this is a #fitbitfail
Best Answer04-30-2020 17:25
04-30-2020 17:25
@Alliek28 you might want to return and edit your post. You have your phone number on there and a website that has personal information on it. These forums are public and anyone can see what is posted here. It's best to be safe.
Best Answer04-30-2020 17:47
04-30-2020 17:47
Thank you! Need to figure out how to deleted that. I didn’t mean to post that thank you for letting me know
Best Answer04-30-2020 17:53
04-30-2020 17:53
How do I delete this? I didn’t mean to post my phone # ... the three dots in right hand corner doesn’t give me an option to delete. THANK You!!!!
Best Answer04-30-2020 18:24
04-30-2020 18:24
Best Answer04-30-2020 18:29
04-30-2020 18:29
@Alliek28 edit it. There should be a way for you to edit. I'll notify a moderator to edit this if you can't.
04-30-2020 18:31 - last edited on 04-30-2020 19:16 by LiliyaFitbit
Thank you, I can’t seem to edit it...appreciate your help 🙂
Best Answer04-30-2020 18:32
04-30-2020 18:32
I notified them, but no idea what hours they work, @Alliek28 You just posted it again. You must have it set to automatically post your number and the website?
04-30-2020 18:40
04-30-2020 18:40
04-30-2020 18:49
04-30-2020 18:49
On your post are three dots, pull down and the first option is Edit. Select that and you're back to the unedited post where you can change it.
