11-05-2018
17:10
15:03
11-05-2018
17:10
15:03
Since upgrading to Charge 3 I no longer get text messages from my I phone to the Charge 3
12-05-2019 16:57
12-05-2019 16:57
Best Answer12-05-2019 20:05
12-05-2019 20:05
Be aware!!!! I had mine exchanged. Now I’m having the same issues with the “new” one!!! I am saying “new” one, because that is what Fitbit told me they would send me. But I had to learn it is a refurbished one which seems to still be connected to the previous owner?!?!?! Fitbit is keeping me on hold for a solution since July 2019!!!!! At that time my charge 3 was just about 7 month old!!!
They are just apologizing and thanking for my patience which I have lost long time ago!
they don’t care at all and don’t take responsibility for their cheap devices that don’t function 100%
I’m sick and tired of this BS company!!!!
Best Answer12-05-2019 20:11
12-05-2019 20:11
When is this issue going to be fixed? This is the only reason I bought this fitbit and it hasn’t worked for months. Please advise as to when it will be resolved
Best Answer12-06-2019 04:04
12-06-2019 04:04
Best Answer12-10-2019 10:23
12-10-2019 10:23
Ok so I FINALLY got it working. The issue seemed to be the Message - Notifications - Always (default).
They keep telling you to go to Notifications, then messages, but it is Messages first, then the notifications on the message screen.
Works like a charm - not sure why they dont do a better job of explaining the fix but I got it to work and I am not one of the fitbit trolls that just says it works when it isnt.
12-10-2019 11:06
12-10-2019 11:06
Thank thank you..works now!!
12-10-2019 14:00
12-10-2019 14:00
12-10-2019 14:17
12-10-2019 14:17
Best Answer12-10-2019 19:16
12-10-2019 19:16
can you tell me the steps. Fitbit techs useless
Best Answer12-11-2019 07:07
12-11-2019 07:07
I have an iphone so if you don't not sure this will be much help - but what triggered it for me was this.
In the iphone Settings - Notifications - Messages - Make sure ALLOW NOTIFICATIONS is toggled on. under SHOW PREVIEWS - make sure it says ALWAYS or WHEN UNLOCKED
THEN go to the Fitbit app - Click on your FACE in the top right. Find your device, ie Charge 3 - and click on that.
Charge 3 - Notifications - Calls (toggle to on if you want them), Text Messages (toggle to on if you want them) and the same for calendar events.
Have someone text you and see if it works. That is how mine worked. Good luck!
Best Answer12-11-2019 07:14
12-11-2019 07:14
Have someone text you and see if it works. That is how mine worked. Good luck to you!
Best Answer12-11-2019 08:07
12-11-2019 08:07
12-11-2019 10:05
12-11-2019 10:05
12-11-2019 10:52
12-11-2019 10:52
My Fitbit 3 hasn't received text or phone notifications for some time. I just spend ANOTHER 40 minutes troubleshooting it with customer support.
I originally called Nov 1st and they said the issue was with IOS13. I got the same reply today.
It's been almost 6 weeks and you still haven't been able to resolve the issue?
Most disappointing.
Best Answer12-11-2019 11:01
12-11-2019 11:01
Doesn't work.
Best Answer12-13-2019 14:17
12-13-2019 14:17
Trying to get text messages on my Fitbit Charge 3 from my iphone. Followed all instructions but the pop up doesnt come up Bluetooth Pairing
Best Answer12-16-2019 18:16
12-16-2019 18:16
Unfortunately the only way I got mine to work is to turn on previews under messages. Go to settings>notifications>messages> and under “show previews” select Always or When Unlocked. But if you’re like me and don’t like text messages showing a preview on your phone for the world to see, you won’t be able to use this feature on the Fitbit. Pretty disappointed by this.
Best Answer12-27-2019 10:51
12-27-2019 10:51
Ah you’ve solved it!! I too wasn’t get text messages through anymore on my charge 3. Just stopped working for me a few weeks ago... all other notification type messages were still showing on the Fitbit... all except text messages. I’ve just turned on preview in the message settings on my iPhone and voila! I too disappointed you have to display the first few lines of text message in my phone especially if I leave my phone visible on a table. Is there any way round this? Thank you
Best Answer12-27-2019 11:25
12-27-2019 11:25
You’re welcome! If you choose “when unlocked (default)” under show preview on your iPhone, it should still work on your Fitbit. And it will only preview your message if your phone is unlocked or if you are looking at your phone if you have face recognition activated. If it is just sitting on a table and you’re not looking at your phone, it should only say the name of the person that messaged you.
Best Answer12-27-2019 11:35
12-27-2019 11:35
Did you ever get this sorted. I have same problem and see it goes back months so I’m tempted to return charge 3 for refund?
