Charge 3 not giving option to scan barcodes
I have an iPhone 11 and a charge 3 premium.the problem I have is there are no options to scan barcodes.Iv went through all settings and can’t find any way of scanning.is there any way I can add this to my food logging
1 REPLY 1
Hi @Becks84, it's great to see you here.
Thanks for the details shared about this situation with your Charge 3. Currently the barcode scanning option is only available if you're using the US food database. If you use another food database, the barcode scanning option won't work. To check which food database you're using, see How do I change my food database?
See you around.
