Charge 3 not holding a charge
Hi, so I've had my Charge 3 for about 7 months now. About last month I started noticing the battery is draining quickly and have to charge it every 3 days, instead of 5 or 7.
Now the battery is draining 50% every day and I have to charge it every other day. I've rebooted it, I don't have all day connect enabled, don't have quick view on, or notifications. So I am really confused on why it is draining so quickly. Is there anything I can do?
2 REPLIES 2
It's great to see you around, @Lincan.
I understand how are you feeling and appreciate all the efforts in trying to fix this battery issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else. 🙂
Yes I did already talk to them and found a solution to the battery problem! They were very helpful.
