05-22-2020 14:00 - last edited on 09-16-2020 19:50 by
This is a new issue - it was holding a charge perfectly until yesterday morning - typically remaining charged for 5 days or more. I recharged yesterday morning and the battery was almost dead before bed. I recharged thinking maybe it really wasn't fully recharged in the morning. The device said around 90% when I put it back on last night. I woke up to it having an exclamation point and the app saying the charge was down to 6%. I plugged back in and charged back to 99%. Within less than 3 hrs it back to under 80%. Was there some type update that could be causing this that happened in the past few days? It seems really odd that the length of time it holds a charge would change so drastically overnight! Not happy! It seems that every fitbit product needs to be replaced within weeks after the warranty expires...
Additional info. I just did a turn off then back on. Hold button for 8 sec while plugged in, then see a smiley. Interesting - the charger showed 96% when I turned it off and went down to 82% when it went back on. Very odd...
05-22-2020 14:27
05-22-2020 14:27
Mine worled fine too. Then started vibrating this evening, wouldnt stop (Had been charged fully last night). Battery said low when charger connected (this stopped vibration). Restarted charge 3, charged it to 90 odd %, an hour later exclamation mark, battery at 3%. Has there been a recent ipdate, as its weird that people having same issue?
05-22-2020 14:31
05-22-2020 14:31
Mine is still going a bit crazy - I kept it charging after it went back to 84%, it got to the 100% showing of a smiley. I restarted again and it's back to 84%. Not sure if it's not actually charging correctly or if it's draining. I've charged multiple ways. The last is via USP to my Dell laptop. Annoyed at this point. Not the economic environment where I want to but a new one...
05-22-2020 14:40
05-22-2020 14:40
Just read a similar story of guy whose battery died not long out off warranty. Fitbit advised yeah your battery is dead, have 25% off new device lol. Bit weird so many people having same issues...
05-22-2020 15:11
05-22-2020 15:11
Did factory reset. Even worse. Charge and app communicate, the 4 digit code appears, when i type into app it says not working lol. Tried this numerous times, each time new code generated. Uninstalled app, restarted phone. Looks like my tracker is kapoot
05-23-2020 02:10
05-23-2020 02:10
I have been having this issue also and my fitbit is not even 6 months old very frustrating
05-23-2020 02:38
05-23-2020 02:38
fitbit completely died overnight, and now wont charge. RIP
05-23-2020 03:55
05-23-2020 03:55
Your post describes my exact experience. Worked perfectly until 5/21 and held a charge. Suddenly died out of nowhere, started vibrating every few seconds, now unable to hold a charge at all. Fitbit is less than a year old, WTF?
05-23-2020 04:03
05-23-2020 04:03
Exactly that. Supposedly fitbit had some sort of server issue overnight causing sync issues, but as mine wont even switch on anymore looks like its curtains. Theres 1 year warranty so you should be fine :), whether you go down fitbit route again is another question however
05-23-2020 04:52 - edited 05-24-2020 06:00
Mine just did the same thing. I updated to iOS 13.5 yesterday. But I was at 82% this morning. I charged it to 100%. I took the dog out, came back in and I was at 7%. Now it's charging again and 87%. I guess we will see how this goes. I never had any issues with my Charge 2. Several with Charge 3.
Update. I recharged again and was at 100%. I'm down to 32% and had to restart. This is nuts.
Another Update: I did a hard shut down of the device. It seems to have worked as I have not had any more charging issues.
05-23-2020 07:46
05-23-2020 07:46
Not sure it's going to hold a charge, but I noticed that the display kept turning on. I finally figured out to to change the setting (it's done from the Fitbit itself, not the app) so I'm hoping that will help!
Best Answer05-23-2020 23:10
05-23-2020 23:10
My Charge3 has just started having the same issue. Seems to lose charge within a day, which prior to these last few days it lasted at least 4 or 5 days
