09-20-2022
13:39
08:18
AndreaFitbit
09-20-2022
13:39
08:18
AndreaFitbit
Fitbit Charge 3, I can charge my fitbit to 100% but if I put it on my wrist it loses all its charge within 2 minutes. It fully loses the charge, down to 0%. I put it back on charger & do the 8 second reboot but this does not seem to help. If I recharge it back up to 100% the same thing happens again. Can anybody help.
Moderator edit: updated subject for clarity and label.
09-23-2022
06:55
10:55
09-23-2022
06:55
10:55
Welcome to the Fitbit Community, @DougieG. I'm sorry to hear about your Charge 3 battery experience.
Please check if your tracker is charging properly with the instructions of: Why isn't my Fitbit device's battery charging? You can also check: Can I extend my Fitbit device's battery life?
Keep on visiting the forums.
Best Answer10-10-2022 00:45
10-10-2022 00:45
If your Fitbit won't charge properly, there are a number of things you can try to get it working again. Make sure the Fitbit's charging contacts are clean, dry, and seated properly in their charger. If possible, try to restart your Fitbit, or use a different charger.
Regards,
Will
