07-23-2019
08:15
10:55
07-23-2019
08:15
10:55
Hello, I updated my Fitbit with the latest update and seem to have stop receiving these reminders to move. I have the setting turned on and my Bluetooth is synced to my phone correctly. Is this a known issue, is their a fix yet?
10-22-2020 00:09
10-22-2020 00:09
Hey guys, mine is working perfectly now. The last update included a new Do Not Disturb (DND) feature that was ON on my Charge 3. Hold down the button and the DND and Sleep options appear. Make sure that this is OFF. I'm receiving my Reminders to move now for the past 3 days so far, no issues and no need to restart the device or unlink and link etc. Just had to turn off the DND.
10-23-2020 23:47
10-23-2020 23:47
Agree wholeheartedly. My Fitbit gets new issues every time I charge it. First the screen stopped lighting when I lift my wrist to look at it, but will open if I tap 3 times. Then it goes completely black and i have to press the button to see anything, and now the notifications (both reminders to move and messages from my phone) no longer work. 5 15 minute resets later and one Bluetooth restart, still not working.
11-11-2020 08:11
11-11-2020 08:11
Thank you!!!! This has been driving me nuts. I can't believe I've been searching for the answer and doing all the recommended resets etc. and fitbit didn't ever bring this up. Disappointing!
01-07-2021 23:01
01-07-2021 23:01
I can never figure out how to tell if it’s on or off! Does the line mean off?
05-27-2021 09:11
05-27-2021 09:11
That whole screen is a confusing, horrible mess of a UI, in my opinion.
DND is dim. Does that mean it's OFF (one might get reminders) or ON?
DND is bright. Does that mean it's OFF or ON?
DND is bright with a minus sign in a circle. Does that mean it's OFF or ON?
Ditto Sleep and Screen Awake.
Whatever happened to simply putting the words "ON" and "OFF", or even check marks to indicate ON, after these words/phrases followed by a colon?
E.g.
DND: OFF
Sleep: OFF
Screen Awake: ON
Is that so hard to do? (Note that the colons are needed so people don't think "DND ON" means "press here to turn DND ON" versus "DND is currently ON". That sort of confusion can be a real challenge when it comes to designing an intuitive UI.)
And if "Sleep: ON" disables DND and/or Screen Awake, just have those show up as "DND: N/A" and "Screen Awake: N/A", and I think most people would get the message without having to trawl through forums like this, make inferences based on the level of light of a portion of the display, etc.
Further, the online info I found says "When you turn off the setting, the icon appears dim with a line through it." Um, no; I see no line through any of these icons, even when dim. (It looks like there's an extremely dim such icon with a line through it; but that's not really legible even in a somewhat-dark inside room, nevermind when trying to figure out this stuff while outside in sunlight. So those icons seem like they're just background images. In general, devices like FitBits, designed to be actively used and viewed in a wide variety of lighting conditions, should never use dimming/brightening as a substitute for displaying actual useful information.)
It's especially weird that even the documentation doesn't simply include a table showing what each icon might look like, along with a simple explanation of what that means, per row.
But the fact that one is even needed is a strong indicator of a poor UI.
06-01-2021 12:45
06-01-2021 12:45
That is the misery of Fitbit Mysteries solved. You think something was repaired during your hokey pokey dance and when you turn yourself about the dance starts over with a different result.
06-02-2021 18:05
06-02-2021 18:05
I did this and now my device started on 12:00 of the next day. However my cell & laptop show the correct info. I am beyond frustrated!!
04-16-2022 19:12
04-16-2022 19:12
I tried rebooting. Reminders to move still not working.
