Charge 3 not receiving any notifications
When I first got my charge 3 the text and phone call notifications showed on my charge 3. I tried to add notifications for WhatsApp and messenger too but this never worked and now none if the notifications are working.
5 REPLIES 5
Hi @emmas73  What phone are you using? Try THIS Help Article on notification issues and see if anything there helps.
Community Council Member
Helen | Western Australia
Hi @NellyG  Thanks for your message - I've got a Samsung S7. Have tried everything the article says and still not working.
Ok that phone should work OK. Check that none of the phones settings have changed - they do changd sometimes when you get an update. In particular check that in the phones settings app, lock screen is set to show notifications. That one got me when I was using an S7.
Welcome to the Forums, @emmas73 and @NellyG, thanks for the input.
I appreciate all the efforts in trying to fix this notifications issue. We are aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
Please let me know if there's anything I may do to assist you in the meantime.
@AlejandraFitbit  Ok so this is a general problem with the charge 3?
Is there a similar forum for the ace 2 as my daughter is having problems with it?
