07-11-2021
16:51
04:27
WilsonFitbit
07-11-2021
16:51
04:27
WilsonFitbit
My charge 3 has not been recording my active minutes for 3 days now and does not buzz when I hit my active minutes goal!
Moderator edit: subject for clarity/format
07-12-2021 04:31
07-12-2021 04:31
Hello @dmcyber. Welcome to the community forums.
I'm sorry for any inconvenience and thank you for taking the time to report this matter. If you've already restarted your Charge 3, I'd recommend performing a long restart to your Charge 3. To complete the long restart, please make sure to follow the instructions below:
Also, take into consideration that your Charge 3 ears active minutes through 10 minutes or more of continuous moderate-to-intense activity. For more information, please check here: What are Active Zone Minutes or active minutes on my Fitbit device?
In regards with the active minutes goal, if your Charge 3 stopped vibrating, I recommend making sure that your Charge 3 hasn't gone into Sleep or DND mode. When any of these settings are activated:
To change this, press and hold the button, and swipe left to access the quick settings screen. Tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it. For more information, see How do I navigate my Fitbit device?
Hope this helps.
