Charge 3 not registering EOV
hi, does anybody know why my fitbit charge 3 stopped recording the oxygen fluctuation in the night. It worked for 2 nights, then it stopped, the only thing I've changed is the straps 🤔
Thanks for your help!
1 REPLY 1
Welcome to the Community, @Spinonepep.
If you move frequently during sleep, the movement can interfere with the light that bounces back to the sensors on your device.
To receive EOV data, note the following:
  • Make sure your Fitbit device is snug and secure before you go to sleep. For more information, see How do I wear my Fitbit device?
  • Make sure your Fitbit device is charged.
  • You must sleep 3 or more hours.
Let me know the outcome.
