Charge 3 not showing correct time
This is probably obvious, but: Charge 3 Suddenly 3 Minutes Behind - how do I set the clock?
1 REPLY 1
It's great to see you around, @jscos.
If your Fitbit isn't showing the correct time, I recommend changing the timezone to a completely different one, sync the device, put the correct time and sync again.
To change the time, follow the steps in the article: How do I change the time on my Fitbit device?. Also, make sure that the device you are using for this has the correct time.
Let me know how it goes.
