12-24-2018
03:45
14:31
12-24-2018
03:45
14:31
My fit bit charge 3 is not showing my heart rate from 4 days..
p.s before it was working very well
suddenly heart rate is not showing
although i did restart but still having same problem
plz solve it as soon as possible
thanks
03-22-2019 17:16
03-22-2019 17:16
Welcome to the Community Forums @Loud76! Occasionally your device may have difficulty getting a strong signal. If you don't see your heart rate on your device, make sure you're wearing it correctly. Review the tips in How do I improve the accuracy of the heart-rate reading on my Fitbit device?
After a few moments, you should see your heart rate again. For additional troubleshooting steps, see Why don't I see my heart rate on my Fitbit device?
Give this a shot and let me know the outcome!
Best Answer12-25-2018 08:35
12-25-2018 08:35
Hey there @SibaK, it's nice to see you around the forums! Thanks for already restarting your Charge 3 in order to sort this out, nice way to go!
While reading your post I was wondering if by any chance your heart rate is not turned off? Open the Settings app > Heart Rate > Off
Additionally, I'd recommend taking a look at: How do I track my heart rate with my Fitbit device?
12-26-2018
05:15
04:29
JuanJoFitbit
12-26-2018
05:15
04:29
JuanJoFitbit
Hi
its on already and i am having still problem
its been one week
plz fix it
I am still having same problem from that day and no one is helping me !!! What to do now ?
Moderator edit: merged reply
Best Answer03-21-2019 19:56
03-21-2019 19:56
Mine is also not working???
Best Answer03-22-2019 17:16
03-22-2019 17:16
Best Answer03-22-2019 17:17
03-22-2019 17:17
I done a restart and got it going! Thanks was worried I wasn't alive lol
Best Answer03-23-2019 07:17
03-23-2019 07:17
Awesome! I'm glad to hear you got it going again @Loud76. ![]()
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Have a great day!
Best Answer04-29-2019 19:42
04-29-2019 19:42
You moderators are insane. Are you programmed to say the same thing to everyone? These solutions don’t do anything to help us out. I bought a versa 2 days ago and heart rate didn’t work. I tried all of your ridiculous solutions and nothing worked. I returned it and bought a charge 3 today. I’ve had it on 3 hrs and have yet to see the heart rate work. Returning this piece of crap too. My charge 2 works fine and have had several of those. Do not tell me there’s no issue with these crap devices. You changed the heart rate sensor to some new type, and they DO NOT work. AT ALL.
06-22-2019 08:23
06-22-2019 08:23
I solved my wife’s heart rate and dim screen problem. I swiped left 3 times, clicked on settings and turned on the heart rate monitor and changed the brightness to auto. I think they were both accidentally changed.
hope this helps if you haven’t fixed already
08-13-2019 00:18
08-13-2019 00:18
Hi,
ive been having a problem with the option to scroll through steps/hr/stairs/calories etc on the clock screen. It records it all and if I swipe up
I can access it all, I used to be able
to just tap on the clock screen and it would click through the stats... and ideas? I’ve reset the watch, changed the clock to a different one and back to the one I was using before... no change...
Many help would Ben much appreciated.
Best Answer01-27-2020 19:08
01-27-2020 19:08
Heart rate has not been showing for over a week now. Battery is also draining extremely fast, like in one day. I have tried all of the resets and, of curse, checked settings to make sure it is on. Nothing works. I’ve only had this for 6 or 7 months. Please provide a solution.
04-13-2020 16:04
04-13-2020 16:04
After the last charge on my fitbit charge3 I put it on and now no heart rate for the last 3 days
04-22-2020 13:25
04-22-2020 13:25
I’ve the exact same problem.
give us a solution, not excuses!!
FITBIT CHARGE 3...what a shame!!
04-29-2020
20:32
04:31
JuanJoFitbit
04-29-2020
20:32
04:31
JuanJoFitbit
THIS is the answer that the moderators SHOULD have given us!
Thanks so much!
Swipe Left 3 times. Go to Settings. Check that the Heart Rate is ON Mine was OFF
Best Answer05-04-2020 19:32
05-04-2020 19:32
were you able to find a solution? i'm going on three days with no heart rate 😞
Best Answer05-04-2020 21:36
05-04-2020 21:36
I’m having the same issue and am very disappointed I’m super careful with my watch and take great care of it and my heart rate stopped working and I’ve tried everything to get it going .. there is a faint green light on one sensor and nothing on the other
Best Answer05-05-2020 02:50 - last edited on 06-18-2020 19:59 by LiliyaFitbit
No they ultimately replaced it as it was still under warranty. If you go this route, do not put the package in USPS. take it straight to Fedex. It took a week for the postal service to get it to FedEx for the long trip to California. I was without a Fitbit for 3 or 4 weeks.
Sent from my iPhone
Best Answer05-09-2020 11:12
05-09-2020 11:12
I have tried everything to make my heart rate on my Fitbit 3 work again but have been unable to do so. It says to go the the Settings app, then to Heart Rate and then to turn it on. Where do I find the Heart Rate so I can try turning it back on? What else can I try? (I have tried restarting my watch several times but plugging it in and holding the side button for 8 seconds). Please help
Best Answer05-09-2020 13:39
05-09-2020 13:39
05-09-2020 14:05
05-09-2020 14:05
