12-24-2018 03:45 - last edited on 11-17-2020 14:31 by MatthewFitbit
My fit bit charge 3 is not showing my heart rate from 4 days..
p.s before it was working very well
suddenly heart rate is not showing
although i did restart but still having same problem
plz solve it as soon as possible
thanks
12-02-2020 08:46
12-02-2020 08:46
Hi,
I used this method pated below originally suggested by Lisa S back in May however just checking now you need to swipe left 4 times to get to the settings option, then make sure that under the heartrate setting it is selected to "ON"
Hope this helps 🙂
Swipe the face 3 times to the left.
Tap on SETTINGS
Swipe up to HEART RATE
If it says OFF then Tap it once to turn it ON
02-06-2021 12:38
02-06-2021 12:38
My Charge 3 worked perfectly fine until a few days ago. First it started showing an incorrectly high heart rate. I calculated it manually with my fingers and an analog clock, and my H/R was it’s usual 70 beats or so (usually lower). I got tired of this (it was actually making me anxious) & shut the H/R option off for a day or so. I turned it on this morning (I’d like sleep tracking back), and now there’s no H/R whatsoever. I’ve reset the device and gone through all the troubleshooting steps except for a factory reset.
I recently got a new Pixel android phone—could that be a factor? I had also gently cleaned the sensor on the device the night before this all began, but not with anything harsh and abrasive. Has my device gone bad?
02-06-2021 13:37
02-06-2021 13:37
This is exactly what is happening to my device now. BTW, I love how the forum won’t let you upvote on the posts that criticize Fitbit about this issue (not). Talk about not taking responsibility. There’s definitely a problem here that needs more than a “swipe left three times and turn the option on” solution. Most of us like our devices, and customer support (I’ve found this excellent every time I’ve used it), but not this ostrich attitude on the forum.
02-06-2021 13:37
02-06-2021 13:37
That also happened to me.
02-06-2021 13:39
02-06-2021 13:39
But this isn’t always the case. My setting is definitely on & I have reset both the device and the phone. Next step: customer service and replacement.
09-29-2021 13:41
09-29-2021 13:41
Yes I realised this as well I assume the update reset this settings because I can see exactly what time it stopped working. I got the idea to check this with the earlier suggestion to restart the device, that made me stumble apon it. Unfortunate that the customer reps only have automated replies
