Charge 3 not showing the correct time
Was having a issue with my Charge 3 and I restarted it and now the time is incorrect. It's about 12 minutes slow. is there away to adjust the time manually?
2 REPLIES 2
It's great to see you here, @SteveJT.
Thanks for troubleshooting the issue you were having with your Charge 3. If your Fitbit isn't showing the correct time, I recommend changing the timezone to a completely different one, sync the device, put the correct time and sync again.
To change the time, follow the steps in the article: How do I change the time on my Fitbit device?. Also, make sure that the device you are using for this has the correct time.
Let me know how it goes.
My time is starting to slow up. It was minutes slow for a couple weeks now it is 7 minutes sloe
