11-10-2020
14:27
12:54
11-10-2020
14:27
12:54
Hello,
since I have installed the iOS 14.1 my Fitbit charge 3 isn’t able to maintain the connection with the Fitbit app. The charge 3 is not detectable as Bluetooth. So synchronization of data isn’t possible. Except when I put the Fitbit in the charger. During this time connection (synchronization) is great.
I have already upgraded the Fitbit app to the newest version and iOS to 14.2 but the issue remains.
The other issue is the horizontal black stripes in my Fitbit screen. The stripes are always on the same place and visible in every menu. (Kind of like broken pixels but in this case entire lines)
I also have an issue with darkness of the screen so I am not able to read the messages or for example heartbeat. But I read a possible solution so I will try that.
I hope you can help me because I was a very happy customer till a few days ago.
kind regards
Danielle
11-11-2020
03:32
10:09
11-11-2020
03:32
10:09
@Devious76 Thanks for being part of our Community!
Let me help you with you with your Charge 3 screen showing lines and not syncing. You can try the following:
Let me know how it goes.
Best Answer11-11-2020 04:50
11-11-2020 04:50
Good afternoon,
I removed the devices from Bluetooth on my phone (iPhone 11) and restarted both phone and Fitbit (charge 3). The synchronization seems to be steady (for now at least).
the horizontal black lines are still there unfortunately. I rebooted my Fitbit twice and still the same result.
kind regard,
D.
Best Answer11-12-2020 11:16
11-12-2020 11:16
Synchronization problems returned after a day. So unfortunately this was not a solution for the long run.
greetings,
D.
Best Answer12-27-2021 12:29
12-27-2021 12:29
I have exactly the same issue with black lines - also display is very faint
following all the steps described did no good
i think I’ll end up moving away from Fitbit. Not happy with this at all
Best Answer12-27-2021 12:30
12-27-2021 12:30
I am experiencing the same issues and am also v unhappy as the suggested solutions do no good
my conclusion? Move away from Fitbit - don’t seem to be as reliable as previously
Best Answer12-29-2021 21:31
12-29-2021 21:31
2nd time this has happened to me with charge 3. Got it replaced in May this year and now it's happened again exactly the same problem. Fitbit have offered me a 35% discount off a new one but I don't find this fit for purpose - it rarely syncs, lines on screen - replacement is 7 months old but isn't covered by their warranty. Very annoyed by it. Done all the troubleshooting steps, restarts of everything, Bluetooth off, delete App etc.
12-30-2021 04:51
12-30-2021 04:51
That's what I got - a 35% discount offer to buy a replacement as apparently out of warranty
Considering my options atm ..........
May go over to an Apple Watch -- who knows!!! There's pros & cons - I do like the FitBit sleep monitoring but not much else between the two otherwise (apart from cost which is only worth considering if you get value for money!!)
