10-08-2018
13:38
15:47
10-08-2018
13:38
15:47
My charge 3 was synced fine with my Samsung s7 but suddenly won't sync. I tried unpairing and re pairing but it wont pair now. I tried with my old iPhone and it won't pair with that either. Any ideas?
12-18-2018 13:07
12-18-2018 13:07
12-18-2018 17:06
12-18-2018 17:06
12-18-2018 17:07
12-18-2018 17:07
12-18-2018 17:13
12-18-2018 17:13
12-18-2018 18:29
12-18-2018 18:29
Did the new firmware update. App said it failed but tracker and app have the new firmware id. The tracker stopped syncing. Did everything you listed. Tried to pair. After inputting the new tracker code it just says connecting. Rebooted both and deleted charge 3 from app. Tried again and still stalled at pair your tracker. What do I do?
Jerry
12-18-2018 19:52
12-18-2018 19:52
Hi Mel, sorry - it can be very frustrating, especially since so many things can impact performance that are not related to tracker (phone, app settings etc.) - sometimes it's tough to figure out what can be the cause of the problem. Let's check few other things... Do you have Always Connected and Keep-Alive Widget enabled? (To check, tap on tracker icon in the top right corner of the Fitbit app and scroll down - they're right on the bottom). If they're not enabled - do so and see if it makes a difference. If Keep-Alive Widget is already enabled - try to disable it and see if it makes a difference. Also, in phone settings need to make sure that Fitbit app has all necessary permissions. To do so go to phone setting, find Apps - tap on it. Scroll down till you find Fitbit - tap on it. Scroll down to App settings -> Permissions. Tap on it and make sure all permissions are enabled. There's also the article from Fitbit that has additional information. If all else fails, try to contact Customer Service for further assistance (I assume you went through the cycle of deleting charge 3 from the linked devices, then reinstalling it, deleting the app and reinstalling it, rebooting the device and restarting the tracker at the same time.... Customer Service will ask you to go through these steps anyway unless you've done them already and they didn't resolve your issue).
12-28-2018 10:42
12-28-2018 10:42
I have restarted my Charge3 multiple times and it is still not syncing. Very disappointing.
12-28-2018 11:58
12-28-2018 11:58
12-28-2018 15:15
12-28-2018 15:15
12-28-2018 16:37
12-28-2018 16:37
I have the same experience with my Note 8 😕
12-29-2018 13:09
12-29-2018 13:09
@Jerry747 did you ever get your issue solved? Mine is having the same issue today. I unpaired it and tried to reset it up and it just won't finish the setup after I put it the new tracker code they give you on the fitbit.
01-04-2019 10:31
01-04-2019 10:31
Hi everybody thanks for reaching out the Forums. If you keep having syncing issues, please check this article with the Fitbit requirements and syncing steps to try: Why won't my Fitbit device sync?
Hope this helps.
01-04-2019 16:50
01-04-2019 16:50
01-04-2019 19:53
01-04-2019 19:53
I was able to sync after clearing user data on the device, everything else didn't work, lost two weeks of data.
01-06-2019 15:22
01-06-2019 15:22
01-06-2019 15:47
01-06-2019 15:47
01-06-2019 15:50
01-06-2019 15:50
01-06-2019 16:02
01-06-2019 16:02
02-28-2019 07:45
02-28-2019 07:45
02-28-2019 07:55
02-28-2019 07:55
Updating it is even worse, it's a nightmare!
