01-20-2020
08:23
17:44
01-20-2020
08:23
17:44
I'm sorry if you read this earlier, but think I posted it on the wrong board. I have my exercise set for spinning which is the closest I could find to stationary biking. Two days ago when I did nothing but drive and sit, the active minutes recorded as 20. Today, when I actually did ride, no active minutes were recorded. Any insight would be appreciated.
01-21-2020 10:01 - edited 02-23-2024 03:16
Hello there @moffett, thanks for stopping by and for the details provided. My first recommendation is to check the help article: What are active minutes?
Note that the algorithms detect subtle differences in exertion that may explain why two seemingly identical activities result in different active minute totals. For example if you took a brisk walk along the same route two days in a row, differences in your speed and exertion levels (e.g. out of breath vs not out of breath, etc) will cause different active minute totals for the two activities.
Because the Charge 3 primarily tracks movement through the use of an accelerometer, it is more accurately detect active minutes for step-based activities (brisk walking, running) than non-step based activities or activities that require more than steps (yoga, tennis). Trackers like the Charge 3, with a heart rate monitor detect active minutes most accurately, since heart rate data allows us to better estimate caloric burn and, in turn, exercise intensity.
Also note that if you're manually logging activities, your Charge 3 uses a standard MET score and your (optional for custom activities) calorie burn to calculate active minutes. Said that, high calorie burn activities will give you active minutes. Therefore, since custom activities don't include a MET score associated, you'll only get active minutes for those activities if you also log a high calorie burn.
If you are working out in a max, and not getting active minutes, as said before, the intensity is necessary to get the active minutes. If you are not getting them, I suggest you to restart your Charge 3 once again.
01-21-2020 11:29
01-21-2020 11:29
Thank you for your answer and all the info. I have the heart rate tracker on my Charge 3. My main question is why would it give me 20 active minutes on a day when I was basically inactive; just driving somewhere and sitting around.
