Charge 3 not tracking heart rate
Charge 3 gives random faults and doesn't react on restarts. No heartbeat registration.
What am i doing wrong?
5 REPLIES 5
Welcome to the Community @Sannie1969
Thanks for the details shared on your post and for the troubleshooting performed prior posting.
To better assist you, please confirm if you have followed the instructions here in order to restart the tracker. As you may know some factors may affect the heart rate reading on your Fitbit device, so please visit the following link: What factors can affect my heart-rate reading on my Fitbit device?
If the issue persists, I recommend trying the following:
  1. Connect the device to the charging cable.
  2. While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  3. The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
  4. The device turns off.
  5. The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  6. Remove the device from the charging cable. The device shuts down.
  7. Important: Plug the device into the charging cable again
Hope this helps.
Cindy|Community Moderator| Did you find my post helpful? Vote for it or mark it as a Solution!
Thanks for the suggestion Cindy, unfortunately the Charge 3 is not responding to a deep restart, only restarts via the "settings screen" wich is a short restart. The problems remain and are not only the heartrate issue. Looks like the side button is not working properly.
Kind regards
I was having the same trouble as she was with my heart tracker not functioning properly, so I’m either a zombie or my device stopped working properly, right? Well, we narrowed down that I’m not a zombie, guess that means my device has failed in under a year?
So did as this listed and after restart my screen is now unusable. And wtf happened? I had tried the “reboot device” first, nothing happened other than a reboot, and heart tracker not tracking, but after this step by step the screen display is trashed, and still no GD heart tracker, can’t monitor sleep, if your heart don’t beat! And I needed this device for that reason. This is now the second Fitbit to fail me, the first would no longer sync to devices, so I purchased another, and both failed not even a year old to just over a year. How would I be able to get them repaired?
After lots of unsuccesfull try outs and reading forums just threw the Charge3 in the bin and got a Charge4. Hope this one survives longer then 1,5 year (a common life-span for the Charge3 seems after reading a lot of posts)
Hi @noobsybotWelcome to the community forums.  @Sannie1969 Thanks for your reply.
@Sannie1969 I appreciate all the troubleshooting efforts to fix this situation. I hope that the new Charge 4 works as expected and you don't experience this kind of difficulties again.
@noobsybot Thank you for following the suggested steps and thanks for your feedback.
At this time, my best recommendation for you, is to contact our Support Team for further assistance. Note that you can contact them through chat or over the phone and you can explain the inconveniences and the troubleshooting steps you've followed. This way they can assist you from there and give a prompt resolution for your Fitbit tracker.
See you around.
