12-07-2018
08:10
14:31
12-07-2018
08:10
14:31
My charge 3 is very intermittent when recording my sleep pattern. It mostly records a basic pattern it has only recorded a detailed pattern about 3 times since I got it 3 weeks ago. I’ve tried moving it’s position but no luck. Am I doing something wrong?
02-26-2019 08:28
02-26-2019 08:28
So i should not select sleep now button but just automatically let charge 3 detect my sleep? That should solve the issue of it not giving me stages but only a pattern?
02-26-2019 08:30
02-26-2019 08:30
I should not seect sleep now but lwt it automatically detect my sleep? M hving the same issue of not getting sleep pattern but only stages
02-26-2019 09:47
02-26-2019 09:47
So just go to sleep without doing anything, the device records everything, its just that the app syncing its not the best, so in the morning if you dont have the correct times, delete the sleep log, enter the real times and you will have sleep stages and everything, i returned mine because it was having the heart rates go crazy sometimes and i dont need a device with bugs
02-27-2019 00:43
02-27-2019 00:43
M new to fitbit. So what i got is to delete the tracked sleep n enter time of sleep n wake up, it wil bring the recoded sleep in stages?
02-27-2019 00:47
02-27-2019 00:47
My cjarge 3 is only giving me a simple pattern for tracking sleep and not giving thr sleep stages.
i wear it 2 inches over my wrist bone. Not too tight and on non-dominant wrist. I got stages twice only on twp weeks. The app is up todate. Pls help!
02-27-2019 00:48
02-27-2019 00:48
For sleep track also?
02-27-2019 04:51
02-27-2019 04:51
02-27-2019 12:01
02-27-2019 12:01
02-27-2019 12:02
02-27-2019 12:02
What do i change manually? The sleep schedule in target for the night? Its confising for me. If you cud pls help ill be really grateful
02-27-2019 12:26
02-27-2019 12:26
I have explained before very simple, go to sleep without doing anything, in the morning delete the sleep log, and enter your hours manually, you will have all the sleep stages and the correct time, thats it simple
02-27-2019 12:28
02-27-2019 12:28
read what i said, it works 100 % , it worked for me, it's just the syncing between the app and the charge 3 that sucks and I have returned mine,
03-20-2019 17:15
03-20-2019 17:15
I have tried deleting and re-entering the time manually and its not giving me the sleep stages still.
So obviously this fix will not work for everyone.
04-10-2019 09:34
04-10-2019 09:34
I restarted my charge 3 by inserting in charger and holding the start button until i saw a smiley face. I tracked my sleep stage the next day. I will keep you updated to see if it keeps tracking.
05-03-2019 14:49
05-03-2019 14:49
This worked for me. It's a pain but I'll do it until there is a fix to this firmware. This is my 8th FitBit and it's not my first FitBit frustration.
05-03-2019 16:47
05-03-2019 16:47
Charge 3 is junk. I bought mine in January. According to the Charge 3, I sleep between 58 minutes to 2 hours a night. In reality, I sleep 6-8 hours a night. The sleep tracking feature is very important to me. Charge 2 tracked sleep stages perfectly. I have spent a ridiculous amount of hours on the phone with Fitbit. I have tried every snake oil “fix” Fitbit walked me through, but to no avail. I asked them repeatedly to replace the pebble as it is clearly a piece of junk. I was told, and yes, this was what Fitbit dared to state, “We’re not replacing your Fitbit because it doesn’t track your sleep. We don’t consider that an important feature.” After hours of “support” calls and frustrating lack of resolve, I lost it. Finally, the company is sending a replacement. Shame on Fitbit. After reading volumes of complaints I am stunned that Fitbit isn’t more concerned about public perception regarding the quality of their products. I bet we’ll see the Charge 3 quietly fade away. My next purchase will be a competitor’s product.
05-11-2019 02:35
05-11-2019 02:35
Why should you mark all these messages as fixed for charge 3 not tracking sleep or tracking with any accuracy as fixed. Non of the people have had you fix the issue!
I am in the same situation. 1 month in and I sleep 2-4 hours?
Tried your only fixes not working. Return this week I guess. No fix=lock the conversation
06-26-2019 06:34
06-26-2019 06:34
Why would using “begin sleep now” prevent tracking of sleep stages? I’ve found that by not using that function my Charge 3 does not accurately track when I go to bed and when I wake up up. And that is when I wear my Fitbit as recommended for a solid heart rate. My average sleep time per night is in excess of five hours excluding restless periods.
06-26-2019 08:31
06-26-2019 08:31
Nope. Did not work
07-02-2019 08:00
07-02-2019 08:00
How does one reboot or restart?I know I am a technical idiot, but I need a manual with steps and picture on how to do everything. I bought the charge 3 to track sleep stages and it is giving me The length of time slept but no sleep stage data. I would like to talk to a live person!!!
07-02-2019 08:02
07-02-2019 08:02
How does one reboot or restart?I know I am a technical idiot, but I need a manual with steps and pictures on how to do everything. I bought the charge 3 to track sleep stages and it is giving me the length of time slept but no sleep stage data. I would like to talk to a live person!!!
