10-10-2018
14:41
15:47
10-10-2018
14:41
15:47
Bought my Fitbit Charge 3 on Saturday. Tracked my sleep first night, hasn’t since for last 3 nights. Have to keep putting it on charger and restarting. Few hours later it appears on watch and phone. Can’t keep doing this! Any ideas?
Moderator edit: format
01-14-2019 05:45
01-14-2019 05:45
I am extremely unhappy with my charge 3. I started my first fast thursday. I bought the fitbit exclusively to track my sleep and use as data for my fast. First night it work perfectly. The past 3, horrible. Absolutely worthless. We need a manual button we press for sleep and wake
01-19-2019 05:03
01-19-2019 05:03
I am very frustrated with the same issue. It seems that every time I charge my Charge 3 it stops tracking my sleep and says "Sleep not tracked". Now my tracker is not syncing at all. Very unhappy with FitBit at this point. I have went to the website and found no answers. I Googled and found your question so I am hoping to see if you get an answer here.
01-19-2019 06:40
01-19-2019 06:40
Unfortunately, I’m in the same boat as you, very unhappy with my charger 3
01-19-2019 06:52
01-19-2019 06:52
01-19-2019 22:03
01-19-2019 22:03
01-19-2019 22:28
01-19-2019 22:28
01-20-2019 03:56
01-20-2019 03:56
01-22-2019 18:37
01-22-2019 18:37
01-22-2019 20:17
01-22-2019 20:17
Restarting with Laptop, resetting. Nothing works. The sleep monitor is horrible. Unfortunately thats why I bought it. I wish I could return it. My sleep patterns change. It never tracks my sleep when I sleep in the day
01-23-2019 17:26
01-23-2019 17:26
I have had some issues with my Fitbit charge 3 losing it’s pairing with my IPhone multiple times per day and not tracking my sleep or syncing with the app after my pairing has gone awry. After trying many things, I have found that going to the app settings for my charge 3 under Account, there is an option “sync now”. After doing this, my Fitbit device now shows the hours slept and when I manually add more sleep time, it shows up on my Fitbit. Crossing my fingers this will help to get my device syncing properly. I also turned off all Day sync. I’m thinking that may have started this trend of losing the pairing. The problem with losing the pairing is all the remedies cause you to lose some activity and your sleep stats seem to always be lost.
01-24-2019 02:41
01-24-2019 02:41
I am starting to think it's Android and not Fitbit at all. I did a factory reboot on my phone and gogfigure my Fitbit worked fine. Google then while adding all these applications back added one called Carrier services, which is a new Android app that's designed to help communication. As soon as it was installed I lost all Bluetooth connection again. I sent that phone back assuming it was software issues I'm currently on my old phone which does not have Carrier services and it's working fine. Coincidence?????
01-28-2019 15:19
01-28-2019 15:19
Can anyone remind me how to do the long reset
01-28-2019 16:04
01-28-2019 16:04
01-28-2019 16:27
01-28-2019 16:27
Attach Fitbit to charger. Then hold down on-off button until you get a full :-).
01-29-2019 04:11
01-29-2019 04:11
I am having the same problem as posted by Jopw. My fitbit Charger 3 tracked my sleep the first night and hasn't since. I have done the troubleshooting and nothing. It tracked my sleep the first night and nothing since.
01-29-2019 06:58
01-29-2019 06:58
Try the hard reset. Worked for me. Attach Fitbit to charger. Hold down on-off button until you feel the unit "beep" and get a smiley face. Takes 15-30 sec.
01-29-2019 08:54
01-29-2019 08:54
I hope this helps, I called FitBit for help and syncing seemed to be the issue. Thought I would share FitBit customer care email below. Debbie
As mentioned during our conversation, since you're experiencing issues related to your sleep data as your Charge 3 is experiencing syncing issues, please see our solutions below:
Please note that syncing may take up to 30 minutes.
Just in case the syncing issue persists and your sleep data is not being shown as it should, please perform a long restart.
To restart Charge 3 using the 15-second method:
In the meantime, please feel free to let me know if you happen to have any questions or if additional assistance is needed. We're here for you!
Sincerely,
Andres G. M. and the Fitbit Team
01-29-2019 21:19 - edited 01-30-2019 03:46
01-30-2019 04:17
01-30-2019 04:17
01-31-2019 20:43
01-31-2019 20:43
My sleep isn’t being tracked consistently either. I’ve tried to suggestions I’ve seen & still, no luck.
