10-18-2023
10:56
13:56
ManuFitbit
10-18-2023
10:56
13:56
ManuFitbit
I can’t see my screen and can’t get it to turn on.
Moderator edit: clarified subject.
10-18-2023 13:51
10-18-2023 13:51
Welcome to the forums @Playbll24.
Thank you for sharing the inquiry regarding your Charge 3.
Before considering other options, I'd like to suggest you take a look on this help article.
11-07-2023 08:12
11-07-2023 08:12
Mine does the same thing every so often, but it's possible to reset it.
What works for me is to place it in the charger, plug it in, then hold down the button on the side for 10 to 20 seconds, then release. Wait a few moments and it should restart itself. Fingers crossed it works for you too 🤞
Best Answer11-07-2023 10:28
11-07-2023 10:28
Welcome back to the community @SiouxieM.
Thanks for taking the time to share with us how do you fix it!
I'm sure it will be helpful to other users.
