02-08-2021
07:23
11:55
AlvaroFitbit
02-08-2021
07:23
11:55
AlvaroFitbit
Hi. My charge 3 isn’t vibrating when I get notifications doesn’t tell me if I have steps to do 10 min before hour up either I’ve tried all sorts abs nothing Is working
02-08-2021
11:58
06:02
02-08-2021
11:58
06:02
@SunsetRunner Thanks for being part of our Community!
Let me help you with this. Check that your tracker isn't in the Do not Disturb mode or Sleep mode by long pressing the button as this will disable the vibration. Also make sure that your phone isn't in silent mode as this will stop vibrations for notifications.
Hope this helps.
Best Answer02-08-2021 13:34
02-08-2021 13:34
I am having the same problem..... my Charge 3 not vibrating for the reminder to MOVE at 10 minutes before the hour ? I have checked the Do Not Disturb and the Sleep modes....all are off.
02-16-2021
10:37
06:02
02-16-2021
10:37
06:02
@AllenS1223 Thanks for being part of our Community!
Thank you for following my previous suggestions. I would like you to remove the reminders to move, save and sync then re-add them again, save and sync and see how your tracker behaves. You could also restart your tracker by doing the following:
I'll be around.
Best Answer02-16-2021 12:25
02-16-2021 12:25
Thank you, that fixed my issues!
Best Answer02-16-2021 12:41
02-16-2021 12:41
I am having the same issue - how do you remove and re-add these reminders?
Best Answer02-16-2021 12:45
02-16-2021 12:45
Best Answer02-17-2021 04:40
02-17-2021 04:40
OK, thanks. I already did that and it's still not giving me the reminders. I'll keep searching.
06:02
06:02
02-18-2021
06:02
06:02
@Janet_Stephen_T Thanks for stopping by!
You can remove the reminders to move by following the instructions in this help article.
@CristiPhillips happy to hear that my suggestions helped you and thank you for helping @Janet_Stephen_T with her issue.
I'll be around.
