12-06-2018 05:03 - last edited on 11-17-2020 14:31 by MatthewFitbit
My Charge 3 went completely blank, I've had it for about 2 weeks.There is no functionality unless it has been hooked up to a charger whereby I'm given a smiley face then the battery just flashes with no indication that it is charging. As soon as i disconnect the charger it completely dies again?
12-07-2018 03:19
12-07-2018 03:19
A warm welcome to the Community @NatsEmma.
Have you tried to restart your tracker? If you haven't, I recommend restarting it by doing the following:
Let me know the outcome.
10-27-2019 09:49
10-27-2019 09:49
Hi, i have this exact same problem.
I have done
1) restarted 8secs.
2) long restart 15secs
3) reinstall fitbit app
4l removed and relinked charge 3 with phone.
As soon as i take the tracker off the charger it does nothing :
1) side button unresponsive
2) tap screen or tilt unresponsive, in fact screen won't switch on
3) it won't sync unless plugged into charger
4) battery shows 100% (can only see this when plugged into charger).
Help, please.
11-04-2019 16:45
11-04-2019 16:45
EXACT same problem and I even bought a new charger to make sure that wasn't the issue....I see this problem has not been resolved...obviously something is going on because the battery symbol flashes only for second on the charger and it looks like the screen is messed up when it does that then the second you take it off of the charger NOTHING
11-04-2019 17:03
11-04-2019 17:03
That is my problem as well.. how to resolve the issue. Please advise.
04-12-2020 22:42
04-12-2020 22:42
I’ve had the same issue!!! I got my Charge 3 about 2 weeks ago(purchased via QVC) & have tried everything! Just wondering if you got your issue resolved at all? Or got it replaced? As of right now I’m still using my Charge 2 although the HR function has completely died but everything else is tracking normally! I just want my new Charge 3 to work so if and when my Charge 2 finally dies I can use it! I’m beyond frustrated in trying to get it to work! If anyone can help! Thanks
04-13-2020 02:37
04-13-2020 02:37
I bought mine through Amazon.
Amazon had a step by step guide on how to try to fix the issues, which I tried, to no success. So I called Amazon customer help, they put me straight through to FitBut customer help who agreed to a replacement there and then.
05-07-2020 06:36
05-07-2020 06:36
I’m having the same issue and have followed the steps. Anything else I can do?
05-07-2020 10:15
05-07-2020 10:15
05-07-2020 11:04
05-07-2020 11:04
C'mon you know you have a back-end software issue with multiple malfunctions - from the device not working at all to battery drainage issues to display problems, yet you offer these useless 'fixes'. It's affecting thousands of users globally. You make us dig for hours on your community boards to fix the issues ourselves - that you know DON'T WORK! My device has been useless for two weeks now, and I've tried EVERYTHING. I have a $149 piece of junk.
06-10-2020 07:31
06-10-2020 07:31
Just like many others I’m having the same issues with my Charge 3. I’ve tried all of the possible fixes with no success. I replaced the 2 with the 3 last year as I had done with the 1 the previous year. Although I have ordered a the 4, I still want my 3 working so that I can give it to my son. Something is wrong with this model and you should be resolving it before you lose customers.
06-20-2020 06:37
06-20-2020 06:37
I've done all the rebooting that I can do and it still doing the same thing. Please respond.
07-06-2020 06:41
07-06-2020 06:41
I am having the same problem as these others, first my time was wrong then I rebooted and the smiley face came on but when I unplugged it it went black and died , I have done this several times I need some advice
07-17-2020 05:39
07-17-2020 05:39
07-17-2020 05:42
07-17-2020 05:42
07-17-2020 05:51
07-17-2020 05:51
08-29-2020 06:40 - edited 08-29-2020 06:41
Yestergay my charge 3 just stopped working without the charger. Reading all these posts with the same issue i wonder if i should even spent 1 penny for a fitbit device. 149 dollar for 1 1/2 years working device is a lot.
