10-01-2019
17:25
10:43
10-01-2019
17:25
10:43
My Charge 3 is less than a year old- I was golfing and after a drive my Fitbit went haywire.
It kept buzzing and seemed to be me stuck between two screens.
As flattering as it is that Fitbit thinks I crushed the ball, I didn’t. Nor did the device come into any contact.
It kept buzzing until the battery died and now it won’t charge.
I read a couple other posts where this happened to users.
If someone from customer support could email me, I’d appreciate it.
10-01-2019 23:24
10-01-2019 23:24
Hi @JBasq I jave flagged a moderator to come and help you
Helen | Western Australia
10-02-2019 07:25
10-02-2019 07:25
Nice to see that you're digging into the Fitbit Forums @JBasq. Let me give you a warm Welcome to our Community. Thanks @NellyG for participating in this conversation too.
I'm sorry to hear that you are experiencing this situation with your Charge 3. If you haven't already done so, I recommend to restart your Charge 3 following the instructions below:
I hope this helps, keep me posted! 😺
Best Answer10-02-2019 18:01
10-02-2019 18:01
Nope. Nothing. Bricked.
now what?
Best Answer10-12-2019 19:24
10-12-2019 19:24
I got it to restart and was seemingly working for about a week, and the same thing is happening
the charge 3 haptic button is malfunctioning.
I took a video of it that I uploaded to drive and can send you a link to.
Best Answer04-22-2020 01:50
04-22-2020 01:50
Did anyone get back to you? Mine is doing the same thing, screen turning off and on even if I am not wearing it and the heartrate thing goes up and up.
Best Answer04-22-2020 02:46
04-22-2020 02:46
I am having this problem. After jogging two days ago it kept vibrating constantly. The battery dropped fast. I plugged it in a d charged it and it keeps dying within an hour or two. The screen goes completely black. I have reset it by holding the side while on charge. I get the smiley face. But today it's not resetting. During the night I had it on charge and it started vibrating out of nowhere waking me up and I had to take it off. This morning it's at 23%.
This problem has come on suddenly. I have my fitbit since September and the battery lasted a week up until now.
I have seen several similar posts. I have gone through all the recommendations of cleaning, restarting and making sure it is in a phone style charger as well as charging from the computer. On the help it says that there is a 2 day wait for response to emails. I am very concerned as it seems so common and I bought both my retired parents the same watch. Can you flag this please.
04-22-2020 03:35
04-22-2020 03:35
i'm also experiencing these issues!
04-22-2020 06:36
04-22-2020 06:36
I have the issue also. The battery started to deplete faster than the usual, then it the display would change a lot on its own. Then it stopped synching, reset, and charging. I bought it less than 1 year ago. I am following responses to this post
04-22-2020 21:05 - edited 04-22-2020 21:09
Mine dropped 23% in 10 minutes. I was shocked.
Has anyone noticed that when they turn off the heart rate tracker it fixes things a bit?
I have reset, both ways on the tracker and with the cable, I have restarted the heartrate monitor, I have cleaned it, etc.
Right now my options are, heartrate tracker on and I burn over 4000 calories as a 5'0" 125lb 32 year old female 😬 OR turn heartrate off and well... What's the point of an expensive step counter...?
