12-07-2023 09:08
12-07-2023 09:08
Hi
I haven't used my Fitbit 3 for some time due to ill health. I put it on to charge and it came up with the Fitbit logo and code 001. Tried to sync to no avail. This is on an Oppo android phone which I have previously not had any issue with regarding the Fitbit.
Steps taken:
- Updated the app, failed to connect via Bluetooth
- Turned off bluetooth on the app, failed to connect
- Hard restart after reading the forum posts, failed to connect, hard restart
- Reinstalled the app, failed to connect, hard restart
It should be noted that I am getting vibrations when touching the button but not all of the time sometimes there is nothing but starts again.
Hope it can be fixed as I can't afford a new one.
12-07-2023 17:19
12-07-2023 17:19
@singe37 , A warm welcome to the Community! Thank you for your message and efforts.
Just to confirm, the hard restart that you mentioned, was by pressing the button for 10 seconds while the Charge 3 was charging, right?
Did you see the Smiley?
Since restarting didn't help, please follow these steps:
12-08-2023 04:25
12-08-2023 04:25
Hi there
Yes the hard boot was done as you described and was connected to the charger.
I get the smiley face but no loading bar.
12-10-2023 17:14
12-10-2023 17:14
@singe37 , Thank you for your confirmation.
Please try holding the button a few seconds longer. If you see the Smiley, try again, but try to keep the same pressure a bit longer until the loading bar appears.
12-11-2023 02:45
12-11-2023 02:45
I have tried as you suggested and held the button for about 20 seconds. No smiley face.
12-11-2023 02:45
12-11-2023 02:45
I do get vibration from the tracker though.
12-11-2023 17:03
12-11-2023 17:03
@singe37 , Thank you for your rely . I've informed Support and they'll be providing further assistance via email . Soon you should receive an email . Keep working with Support.
