04-05-2019
11:10
11:10
04-05-2019
11:10
11:10
Fitbit only vibrates when on charge and screen is blank. When you take it off charge screen is blank and cannot reset and vibrates like battery is no good.
08-30-2021
04:14
07:27
08-30-2021
04:14
07:27
Hello everyone. @Vatsan Welcome to the community forums.
Thank you very much for the detailed information and for the troubleshooting steps you've tried. It seems that you have also followed the recommended tips in this thread and since the issue has persisted, my best recommendation is that you please reach out to our Support Team for further assistance.
Note that you can contact them through the link provided in the thread or you can click here to get connected. Also, take into consideration that you can contact them through chat or over the phone, but phone wait times are longer than normal, so I recommend initiating a chat.
Please make sure to provide a brief explanation of the inconvenience and mention the troubleshooting steps you've followed, this way they can assist you from there.
Best Answer04-06-2019 06:56 - edited 08-19-2023 07:28
Welcome to the Fitbit Community @MaggieJane! Thanks for trying to restart your Charge 3. Nice way to go!
If your Charge 3 is only vibrating when being charged, I'd recommend changing the clock face to a different one.
While your Charge 3 is being charged you can change the clock face, please don't take it off.
Best Answer05-22-2020 10:40
05-22-2020 10:40
I have same problem and unfortunately sugested solution is not helping.
Best Answer08-29-2021 23:17
08-29-2021 23:17
Maggie - Did you get a solution that worked? I ran into the same issue with my Charge 3...Fitbit vibrates when pressed while charging- but continues to have a blank screen both when charging and off it as well. Long resets and changing charging ports and cleaning and all other things have not worked.
04:14
07:27
08-30-2021
04:14
07:27
