Charge 3 pairs to my iPhone but not my iPad
I was able to successfully setup and updated my brand new Charge 3 (purchased to replace my One) to my iPhone SE 2020, but it doesn’t connect to my iPad. When I try to get the pin code to setup with the iPad...nothing happens. I usually use my iPad for syncing. Help!
3 REPLIES 3
When I removed the One from my account, it started syncing. I guess both cannot be on the same account.
Syncs on iPad, iPhone cannot find Charge. The notifications area shows the spinning star. I get the need to pair pop up, and when I click setup...nothing. Argh!
Moderator edit: word choice
@SunsetRunner   First, you can have your One and your Charge 3 on your account at the same time.  Second, if you set up your Charge 3 to receive notifications from your iPhone, it makes a tight Bluetooth bond with your iPhone.  It won't sync with your iPad if your Notifications are on.  Also, if you set up your Charge 3 with your iPhone, it is on your account.  You don't need to set it up again on your iPad.  You data syncs to your account, not your iPhone or iPad.
Laurie | Maryland
