11-16-2020
19:47
10:13
11-16-2020
19:47
10:13
I have reset my unit a couple of times and have stopped all arm movements 15 minutes before the hour with 235 steps showing. 5 minutes after the hour the unit reset to zero steps without ever vibrating. No vibration. In settings mode there is no difference between strong and normal, but both do vibrate in the normal style. Is there anything else I can do to correct this problem. Setting at my desk I need this vibration to remind me to move.
Thanks
Moderator edit: format
11-17-2020 04:21
11-17-2020 04:21
Hi @turbo51, it's great to see you in our Fitbit Community. I'm sorry to hear that your Charge 3 quit vibrating with less than 250 steps and the vibration won't be different between the normal and strong settings. By the way, thank you for trying to get this issue resolved before contacting our forums.
I'd like you to try a long restart. To do so on your device, follow the steps below:
After this, monitor your tracker and see if it vibrates properly for the 250 hourly steps and the vibration intensity gets corrected as well.
Keep me posted on the outcome.
Best Answer11-17-2020 16:42
11-17-2020 16:42
It did not change anything. Not getting any vibrations. in the settings there is still no difference between normal and strong.
