11-19-2018 18:15 - last edited on 11-17-2020 14:31 by MatthewFitbit
I’ve had my Fitbit Charge 3 for almost 2 weeks, wearing it consistently, however the sleep tracker has never worked (nor has the water indictor). It is a new device, all updates are current, I have tried manually syncing and restarting the Fitbit but despite the app showing sleep details, my Fitbit Charge continues to show “sleep not tracked”. I have read numerous “solutions” on here but none appear to work. Is it time to get my money back?
03-28-2019 11:39
03-28-2019 11:39
Welcome to the Fitbit Community @mipatterson! Thanks for the details provided about your sleep data not being synced.
While reading your post I was wondering if your sleep data was missing from the Fitbit Charge 3 or the Fitbit app after syncing?
As you may know, sleep stages are based on heart rate data, so make sure that you're getting a solid heart rate reading , since sleep stages requires consistent HR. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight. Also, double check that your watch is charged up.
Additionally, I'd recommend checking the following that could be preventing you from receiving sleep stages:
For more information about why you see your sleep pattern, tap or click the sleep record that shows your sleep pattern.
If after testing the above suggestions for the next couple of nights your Charge 3 is still not giving your sleep stages, I'd recommend doing the following steps:
1. Manually sync the tracker. See instructions in How do Fitbit trackers sync their data?
2. Restart your Fitbit device. See instructions in How do I restart my tracker?
3. Try sleeping with the tracker on your non-dominant hand.
4. If steps 1-3 don't work, I suggest to manually log sleep to reflect the time slept. See instructions in How do I change my sleep history?
Give this a shot and let me know the outcome.
11-19-2018 19:02
11-19-2018 19:02
Are you saying that the sleep details show on the app, but on the tracker it says not tracked?
I'm not sure why the tracker itself is saying that, but, for me at least, the main thing is that it is getting to the app and to the Fitbit database. On the tracker itself, the most you could see is the amount of sleep for the past night, whereas on the app you can see stage details and history.
11-20-2018 03:35
11-20-2018 03:35
Yes, it shows on the app but not the tracker - my Flex 2 did this! I’ve now upgraded to a Charge 3, so I don’t think it’s too much to expect it to work!
11-20-2018 05:12 - edited 11-20-2018 05:12
Welcome to the Fitbit Community @Lapvol! Thanks for letting us know about this issue. We’re aware of it and are working to identify a resolution as quickly as possible. We appreciate your patience and look forward to getting you back on track.
Additionally, I'd recommend taking a look at the following articles:
Thanks a lot for trying to help @JohnnyRow!
Please let us know if there's anything we can do to assist you in the meantime.
11-23-2018 16:04
11-23-2018 16:04
Same problem, with my new Fitbit 3
11-24-2018 05:51
11-24-2018 05:51
Welcome to the Fitbit Community @binualexander! Sorry to hear you're also experiencing this inconvenience. As soon as we have updates about this, we'll make sure to post them in this thread.
As mentioned, our team is working to identify a resolution as quickly as possible.
We appreciate your patience and understanding!
11-25-2018 19:42
11-25-2018 19:42
Thank you, Support folks.
Appreciate your working on this.
11-26-2018 06:52
11-26-2018 06:52
Our pleasure @Larkster! I really appreciate your understanding while we work on this.
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
If there's anything else I may assist you in the meantime, let me know.
11-29-2018 03:51
11-29-2018 03:51
Same problem, please help! Brand new FitBit 3
Thanks for looking into this 🙂
11-29-2018 04:50
11-29-2018 04:50
Hey there @LaviniaM, welcome to this thread! I'm really sorry to hear you're having this inconvenience too. I've been reporting this to our team, as soon as I get any updates I'll post them here.
Stay tuned and let me know if there's anything else I may assist you with.
11-29-2018 06:27
11-29-2018 06:27
It's working now! 🙂 excellent!
Thank you!
12-07-2018 00:18
12-07-2018 00:18
Hi @MarreFitbit , I have had Charge 3 for about a week now. Have read the forums suggestions about 'sleep not tracked' on the Charge 3. None of them have worked for me. Are you able to get my account looked at in case it's something else? I've tried restarting the Charge 3 both through software and through plugged in and pressing button. Uninstalled app, unlinked Charge 3, reinstalled app, re-linked Charge 3. Also tried turning off and unlinking Charge 3 from Blutooth and then re-linking. Sleep is being tracked on my app and also on desktop, however, still shows 'sleep not tracked' on my Charge 3 device. Would appreciate some well informed advice.
12-07-2018 10:15
12-07-2018 10:15
Still "Sleep not tracked" on my Charge 3.
Really? ... is it suppose to work now?
12-18-2018 13:00
12-18-2018 13:00
12-20-2018 22:57
12-20-2018 22:57
@MarreFitbiteven after Firmware update 1.49.45 - still 'sleep not tracked' status on Charge 3.
Have restarted both methods with and without charger.
Have synced many times (app is fine, device doesn't seem to work/show slept hours, just shows 'sleep not tracked').
01-08-2019 07:43
01-08-2019 07:43
I am having the same problem as well where sleep and water are not syncing on my new Charge 3 - it looks like this problem has been ongoing since late last year - any updates @MarreFitbit???
01-22-2019 16:43
01-22-2019 16:43
I can't track my sleep as well with the charge 3.
02-16-2019 00:36
02-16-2019 00:36
Hello everyone, I have good news! My Charge 3 now shows the amount sleep in hours and minutes on my watch. From day one it has not worked, not mattter how many syncs, resets, app updates, device updates etc. It was so frustrating that something so simple had not worked from the start, yet clearly was showing in the App (only). Today, I had a sleep for about 1.5 hours and as after each sleep (even if less than 3 hours), I sync and pray and hope that it would show on my Charge 3. Sadly it did not show. Then I tried something that worked for me, try this and good luck!:
Open the Fitbit App on your phone.
Press the heart (it will open up the Heart rate screen).
For each day that shows horizontal dashes ie "----", press that day and allow it to load on the screen.
Go back (to the heart rate screen). The details won't show yet. But keep scrolling down and make sure you press on any horizontal dash that looks like it hasn't loaded.
Once you have pressed all the horizontal dashes, go back to the main App screen.
Then, go back into the Heart rate screen.
All the days you clicked that previously had horizontal dashes, should no longer show as horizontal dashes but actually heart rate lines.
Go back to the main App screen, then Sync.
..... let me know how it goes!
It's definately a syncing issue with the heart-beat. As it can't/hadn't sync'd the way it needs to, it seems to get stuck and prevent the sleep data from loading into your Charge 3. That's my guess.
Hope that mine continues to work :).. after 3 months of trying!!
02-16-2019 14:36
02-16-2019 14:36
Thank you for sharing ...
I have no "-----" in FitBig app/Sleep.
Sleep still not tracked even close to correctly - the status since I bought my Charge 3 end of November.
02-16-2019 14:59
02-16-2019 14:59
Oh dear, after another nights sleep, it's reverted back to sleep not tracked, despite me doing the things I advised above. But at least I have a little more hope and know that it's possible. I was thinking maybe return my Fitbit for a new one of the same model. Boooo. Will keep people updated on any further success if consistent.
