06-13-2019
14:36
10:55
06-13-2019
14:36
10:55
I just bought my charge 3 about a month ago. This past weekend it started constantly vibrating and switching screens on me. Itll turn notifications off randomly or turn my screen wake of. It then doesn’t respond to touch and won’t stop. This has been happening for hours today the longest it’s been and it’s getting pretty frustrating and not sure what to do
06-14-2019 08:38
06-14-2019 08:38
Welcome to the Community Forums @JLeyva! I totally understand how you feel. Thanks for already restarting your Charge 3 to solve the issue.
Since the restart didn't work, I'd recommend restarting your device using the 15-second method:
If this step doesn't work either, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
I'll be around, keep me posted. ![]()
09-14-2019 20:10
09-14-2019 20:10
My Fitbit charge 3 starting vibrating and randomly switching screens. I have had it since November 2018 and no issues until now. I have read multiple posts and tried reseting multiple ways with no luck correcting the issue. Please offer some insight as I get really annoyed when it starts doing this. I love this device but not at the moment. Thank you in advance for any assistance.
Best Answer09-22-2019 06:14
09-22-2019 06:14
Following the steps to do both restarts and change the clock face and mind is still doing this. What now?
Best Answer10-19-2019 04:17
10-19-2019 04:17
I’m having the same issue today. I have also tried the instructions to reset and change the screen it still keeps vibrating and switching screens. Are there any other solutions??
Best Answer10-19-2019 05:14
10-19-2019 05:14
Mine doing the same. Can't reset due to switch activating all the time
07:39
04:17
JuanJoFitbit
10-19-2019
07:39
04:17
JuanJoFitbit
Mine is doing this too. Can't turn off. Can't find new clock face on app.
Okay found new face but it hasn't helped!
Moderator edit: merged reply
01-11-2020 13:28
01-11-2020 13:28
Hello Fitbit,
I have the same problem. Followed all your suggested steps (15 sec restart / sync app / change clock) but there problem remains. Please let me know what to do.
14:35
05:00
JuanJoFitbit
02-15-2020
14:35
05:00
JuanJoFitbit
Same issue as stated, unable to do anything functionally as it continues to vibrate and switching screens.
What other options we have?
and unable to connect to the device
02-16-2020 23:14
02-16-2020 23:14
Best Answer06-07-2020 10:37
06-07-2020 10:37
I'm having the same issue and it's draining my battery even though it was fully charged a day ago. I can't do any tracking and doing the suggested resets/etc have not worked
07-07-2020 09:32
07-07-2020 09:32
I have completed the reset but changing clock face just hangs. Like another user, Iit seems the battery is draining quickly too. Please provide further assistance.
07-10-2020 14:14
07-10-2020 14:14
I have the same issue. I’ve followed all steps and the problem is not corrected. In addition to these problems it does not hold a charge for more than a few hours. Please help.
09-15-2020 00:40
09-15-2020 00:40
I have the same issue and your advice us not solving it. Now it is not reacting at all, and not able to sync as it tells me my device is not found. I am so frustrated. This is the first time in my many years if Fitbit that I consider leaving Fitbit
10-20-2020 02:34
10-20-2020 02:34
I’m having the same issue and the instructions above haven’t fixed it. What’s next?
Best Answer10-20-2020 04:33
10-20-2020 04:33
Left Fitbit, goodbye!
11-16-2020 18:15
11-16-2020 18:15
I am having the same issues even after trying all the steps you have provided is there anything else I can do to fix this thank you
12-06-2020 14:53
12-06-2020 14:53
Did you ever find a solution? Mine has started doing this today. Thanks.
12-07-2020 00:03
12-07-2020 00:03
No, and no response from Fitbit. I gave up and left Fitbit after 7 years.
04-24-2021 13:23
04-24-2021 13:23
I have the same problem. Solution does not work. Between this and the strap problems I am thinking I will ditch Fitbit.
