01-05-2020
18:40
19:53
01-05-2020
18:40
19:53
01-05-2020 20:45
01-05-2020 20:45
Hi @Andrealynn12 Try restarting your Charge 3 several times and also try a Long Restart. If neither of those fix it then you will need to contact Support
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
08-08-2020 00:46
08-08-2020 00:46
This didn't work for me
Best Answer08-08-2020 02:10
08-08-2020 02:10
@foodiechef Then contact Customer Support
05-22-2022 11:13
05-22-2022 11:13
Thank you..so far the long start worked for me.
05-22-2022 17:42
05-22-2022 17:42
Hi @Myfb2022 That is good to hear. I hope you don't have any more trouble with it.
