02-28-2019
09:13
11:22
02-28-2019
09:13
11:22
I'm having the same problem described here https://community.fitbit.com/t5/Charge-3/Charge-3-is-showing-white-vertical-lines/m-p/3305047#M44483
It happened after charging after running out of battery.
What should I do? My screen works but it has vertical lines all over the place.
11-16-2020 07:42
11-16-2020 07:42
Hello. I have the same issue with this fit bit. Restarting doesn't work. Please can you advise what to do next? Thank you.
Issue is regarding white lines/corrupted dosplay image.
11-16-2020 07:56
11-16-2020 07:56
I have found no fix for this.
11-21-2020
10:34
18:08
DavideFitbit
11-21-2020
10:34
18:08
DavideFitbit
Just set up my new Charge 3. all is fine until after the finalization of the set up. Then, all get a vertical line. I tried the hold the button thing, several times: all I get is a smiley face and then the vertical line.
I re-set the set up several times: same issue.
Oh, it's not a vertical line, it's an horizontal line!
11-21-2020 12:56
11-21-2020 12:56
Hi there,
I’m also experiencing the same issue!! This is so unfair! I bought a Fitbit for my bfs mother who saw the stripes when it was freshly opened from the box. Luckily, they replaced it very quickly.
Now it’s happening to my Fitbit. I’ve tried restarting and changing the clock face! Not gives the issue. This is a common issue for Charge 3, seeing all the posts and forums since 2019. I emailed support and hope to get a response soon! I’m currently in Shanghai, so really hope I get support.
11-21-2020 14:59
11-21-2020 14:59
This is my 3rd fitbit and the first time I have such an issue. It is extremely frustrating!
01-12-2021 12:04
01-12-2021 12:04
Hi Sir
Ive been using my Charge 3 past one year and just this evening i found that the watch has white / grey vertical stripes. I tried restarting and also tried changing the clock face but nothing changed.
Is it possible to kindly organise for the support team help em out.
01-13-2021 17:57
01-13-2021 17:57
I have a Charge 3 as well. I attempted to hard reset, soft reset, and factory resent and I am still getting the vertical lines. HELP!
02-07-2021 10:24
02-07-2021 10:24
My Charge 3 shows vertical black lines/missing white lines - still after attempted hard reset, soft reset, and factory reset.
A ~ $130 device should last longer than 2 years. Is there a solution? If not, having read all of the similar problems described, I will NEVER buy another Fitbit product.
04-20-2021 04:30
04-20-2021 04:30
I do have tried same steps on my Charge 3 multiple times and cannot get rid of the vertical white lines
04-23-2021
05:06
10:25
04-23-2021
05:06
10:25
Hello everyone. Thanks for participating in the community forums.
I'm very sorry for the experience and thank you for following the suggested troubleshooting steps. If you haven't done so, I recommend contacting our Support Team for further assistance. You can contact them through chat or over the phone. Click here to get connected.
Please make sure to explain the situation and the troubleshooting steps you've followed, this way they can continue assisting you from there.
See you around.
04-23-2021 05:20
04-23-2021 05:20
Seem this is command problem for charge 3 , I have two with same issues, try to reset and no change, unlock all over one year, and only one and half year start the problem. Is this a software issue? Or hardware issues? Is this is software , why never been fix?
if this is hardware issues, then will be designed faults, why not cover in the warranty?
04-23-2021 11:25
04-23-2021 11:25
I am also now having this same issue.
I have tried to do the reset by plugging it into the charging cable and it won't do that fully either it gets half way and just turns back on normally.
My charge 3 isn't even a year old yet what do I do?
04-23-2021 11:39
04-23-2021 11:39
04-24-2021 18:06
04-24-2021 18:06
04-30-2021
04:54
09:53
04-30-2021
04:54
09:53
@DNF @moemaloney1969 Thank you very much for your great input! I'd like to let you know that in order for you to receive further assistance and information about your inquiries, I recommend contacting our Support Team. Please note that you can contact them through chat or over the phone and you can click here to get connected.
Take into consideration that replacement devices are provided for products within the warranty period. If your original Charge 3 devices are no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty.
