11-22-2018 03:44 - last edited on 11-17-2020 14:34 by MatthewFitbit
I have had the Charge 3 for 5 days and even though my Fitbit states it is not taking sleep, my android is collecting data from my sleep patterns????.
I tried restarting the fit bit but putting it on the charge and holding the button down didn't start the reboot process. It went to fitbit pay. Any ideas on why that is?
11-22-2018 05:30
11-22-2018 05:30
I find the restart process using the button a bit unreliable and fiddly, while others seem to find it works well. But the good news is there is an alternate way to do a restart on the Charge 3 as long as your screen works Ok (which yours seems to be). Go to the settings app on the watch and scroll down to About and then Restart.
Helen | Western Australia
11-22-2018 12:48
11-22-2018 12:48
Hi Nelly,
Yes, I did that first and restarted it. Didn't fix the issue though.
And another thing I miss is the motivation messages you would get on the charge 2! Just a small thing but nice to read first thing in the morning.
11-22-2018 14:24
11-22-2018 14:24
@JaydeeTas wrote:Hi Nelly,
If the tracker says sleep is not tracked but the data shows on your dashboard then it's a known bug. Should be fixed sooner than later.
11-23-2018 02:52
11-23-2018 02:52
Thanks CLT, I will see how if it ever gets sorted...
11-23-2018 04:20 - edited 11-23-2018 04:23
@JaydeeTas I do not have my Charge 3 on All Day Sync. When I wake up, my tracker says Sleep Not Tracked. But the correct sleep time is there after a sync. Are you saying that your sleep time does not appear at all, even after a sync?
My experience is consistent with the description in the Charge 3 Manual.
Laurie | Maryland, USA
11-23-2018 10:57
11-23-2018 10:57
@LZeeW wrote:@JaydeeTas I do not have my Charge 3 on All Day Sync. When I wake up, my tracker says Sleep Not Tracked. But the correct sleep time is there after a sync. Are you saying that your sleep time does not appear at all, even after a sync?
I don't know what page you mean that indicates that there is or is not a bug. Sleep tracking is done by the Charge 3. If it's tracking but says it isn't then it's the bug so it seems to be affecting you too. Maybe it's affecting everyone, I don't know.
In this case the OP is getting the data but also the not tracked error.
11-23-2018 14:40
11-23-2018 14:40
Hi @LZeeW,
The charge 3 constantly says "Sleep not tracked" If I open my fitbit app on the Android and it has all the stats of my sleep. It's just annoying.
11-24-2018 02:13
11-24-2018 02:13
@JaydeeTas I am sorry that I misunderstood what you are experiencing.
Like @NellyG suggested, and you have done, Fibit recommends restarting your tracker when it misbehaves. When that doesn't work, then it is time to contact Support.
11-24-2018 04:44
11-24-2018 04:44
Hey guys @JaydeeTas and @CLTGreg! Thanks for letting us know about this issue. We’re aware of it and are working to identify a resolution as quickly as possible.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Thanks a lot for all you help my friends @LZeeW and @NellyG!
Please let us know if there's anything we can do to assist you in the meantime.
11-24-2018 05:18
11-24-2018 05:18
Could you please update me to as im having the same isuses , sleep tracking on phone is working , but fitbit says sleep not tracked ,also everytime i check my sleep patterns its copys it but if i delete it it deletes the whole log , thank you Byron
11-24-2018 05:30
11-24-2018 05:30
Hey there @UMTByronK5098, thanks for jumping in here! Totally, as soon as we have updates, we'll make sure to post them in this thread.
In regards to the sleep logs on your app, when you swipe to see the information from previous days, only the Main tile (steps, floors, calories burned, active minutes and distance) will update. The other tiles will only show "Today's" information. In order to check the information from previous days in tiles such as Water, Sleep and Reminders to move, please tap on each tile, where you will find detailed information and a complete graph of your stats.
I hope this can be helpful, if after tapping the sleep tile you're still not able to see the logs from previous days, please let me know and if you need anything else, feel free to reply!
11-24-2018 06:29
11-24-2018 06:29
11-24-2018 07:20
11-24-2018 07:20
Did you try to send screen shots @UMTByronK5098? If so, they didn't go through my friend.
In order to add a photo to your reply, please:
* When you're in the reply page, click on the Photos icon.
* Then, click on the Choose File in the middle of the grey window that will pop up
* Search for the photo on your computer and click on Open.
* Once the image shows up in the grey windows, select the size and the position (1) and click on Done (2)
I hope this can be helpful; give it a try, I'll be waiting for your reply!
11-24-2018 16:48
11-24-2018 16:48
@MarreFitbit wrote:Hey guys @JaydeeTas and @CLTGreg! Thanks for letting us know about this issue. We’re aware of it and are working to identify a resolution as quickly as possible.
Whoa. 15 javascripts on 15 different sites just to hit "Quote"! Are we missing any functionality? Are there stats or something that will show when it's fixed or will it just says "Sleep Tracked".
11-25-2018 14:17
11-25-2018 14:17
These are the photos re. other message
11-27-2018 07:50 - edited 11-27-2018 07:51
Thanks for getting back and for providing me with the screen shots provided @UMTByronK5098! You're experiencing what has been discussed along this thread. As I mentioned, we’re aware of it and are working to identify a resolution as quickly as possible.
You will see your data tracked on your device @CLTGreg.
If there's anything else I may assist you with, let me know.
11-27-2018 11:57
11-27-2018 11:57
Dear all,
Just wanted to let you know I have the same problem.
I fixed it once by hanging my fitbit by the charger on the computer and syncing the fitbit with the fitbitapp on the computer. After that my fitbit did show my sleeptime that day.
But the next day again the same problem, and my earlier solution wasn't working anymore.
Just wanted to let you know, maybe it helps in fixing the bug?
Just one last question, I am new in the fitbit community and when you say you're gonna fix the bug as soon as possible.. Are we speaking days-weeks-months...?
Thank you
01-07-2019 09:56
01-07-2019 09:56
So how long is it expected to take to fix this bug?
I have the same problem and I'm not impressed spending £150 and some of the functions don't even work properly.
It also takes a VERY long time to sync to my phone even though all day sync is in and every setting that is supposed to make syncing easier and quicker is turned on.
01-17-2019 11:18
01-17-2019 11:18
I am having this same error message. Is this still not fixed?
