03-23-2021
18:35
10:22
AndreaFitbit
03-23-2021
18:35
10:22
AndreaFitbit
Charge 3 screen cannot be seen outside. It's useless to track anything even time. Tried auto and normal brightness. Neither works.
Moderator edit: format and labels.
03-24-2021 10:17
03-24-2021 10:17
Welcome to the Fitbit Community @tlbrady. Thank you for sharing your Charge 3 inquiry and for letting us know that you've tried auto and normal brightness.
If your Charge 3 display is too dim you can try restarting it:
You can restart your tracker from your wrist. Open the Settings app and tap About > Reboot Device.
If your Charge series tracker is unresponsive: .
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
