Charge 3 screen doesn't come on when I turn my wrist
ANSWERED
My Fitbit Charge 3 screen doesn't come on when I turn my wrist to look at it, I have had it two weeks and up to yesterday it did. Now I have to tap the screen to see anything. I did the latest update when I bought it. Not a big problem but it has me puzzled.
1 BEST ANSWER
Accepted Solutions
@SunsetRunner, have you verified that Quick View is enabled on the tracker?  Press & hold the side button for a few seconds to display Screen Wake - If it is disabled, it has a diagonal line through it.  You can tap on the icon to toggle if On or Off.
53 REPLIES 53
Thanks Larry worked a treat so simple when you know how. 🙂
Great to see you around @SunsetRunner and @USAF-Larry thanks for the input.
I am glad to see here that our friend replied your inquiry about quick view. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping! Smiley Wink
Worked like a charm! Thanks.
Hey @Ginikramer, thanks for joining us.
It's awesome to hear that the instructions provided worked and that your tracker is now working properly. Let us know if you need anything else.
Keep the stepping up! Smiley Happy
Screen Wake is enabled but face turns on maybe on 10% of wrist flips 😞
I had the same issue.  Problem solved!!!  Thanks!
Genius 👌👏
That was so helpful thank you!!
Hey @MikeysLala, it's great to see you around.
It's great to hear that the instructions provided by our friend worked and that your Charge 3 is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
Thank you! It worked 😁
Those are great news @CarolS.. I am glad to hear that the instructions provided here worked and that your tracker is now working properly. If you need anything else, do not hesitate to post it.
My screen wake is on and my tracker still will not turn on with turning my wrist. Any other solutions?
Thank you
Thanks so much. I am assuming mine got turned off somehow when i was in the pool two days ago. Thanks again. It works perfectly now👍
Hey @thomaseh03, it's great to see new faces, welcome!
It's great to see here that these steps are helping more friends. If there is anything else we can help you with, do not hesitate to post it.
I will see you around. Smiley Happy
I have a charge 3, the setting is enabled to view when I flip my wrist BUT it's still not turning on automatically.  It was working prior to yesterday  when I went swimming.  Everything else seems to be working fine.
Thank you for this!! I was so confused!
