10-22-2019
09:26
10:40
10-22-2019
09:26
10:40
My Charge 3 used to turn on whenever I flipped my wrist toward me. Now the only way the screen will turn on is if I hit the side button. I've tried the plugging it in and holding the button down routine and messed with the clock face and it still isn't working. Not a major issue, just annoying when you got used to not having to press anything 😕
10-24-2019 12:55 - edited 09-25-2024 13:13
Hi there @ApiFit and @Mfunk1408. I totally understand where your concern is coming from. Thanks for letting me know about your Charge 3's behavior.
So I can move forward with the next step, can you please confirm if you've tried restarted your Charge 3?
If the restart doesn't work, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
I'm looking forward to your response, keep me posted.
10-22-2019 11:07
10-22-2019 11:07
Having the same issue. Able to sync and use side button ok but it’s frustrating
10-22-2019 13:31 - edited 10-22-2019 13:32
Hi there @tlynnc312 and @Ttse, welcome to the Community Forums. Thanks for troubleshooting your Charge 3 devices prior to contacting us and for the details provided.
Have you verified that Screen Wake is enabled on Charge 3? Please try these steps:
If the Screen Wake is enable, but not working as it should I'd recommend restarting your device by following these steps.
Give this a go and let me know the outcome.
10-22-2019 15:38
10-22-2019 15:38
You're lucky... My screen won't come up at all! I can't turn it on then off, I can't hit any buttons, change the clock face. I don't even know what to do at this point. It is a paper weight on my wrist!
10-22-2019 15:59
10-22-2019 15:59
Hi there @KSadyLady, welcome on board. Thanks for restarting your Charge 3 and changing the clock face in order to solve the blank screen.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to help you in the meantime.
10-22-2019 17:42
10-22-2019 17:42
I am having the same exact problem with mine. It’s upsetting to know you’ve spent so much money on a device for it to not function as it’s suppose to.
10-22-2019 18:24
10-22-2019 18:24
I am having same problem. Makes vibrating noise when pressing side button. Holding for 8 sec while charging brings up smiley face but then goes dead again.it is frustrating.
11-02-2019 11:22
11-02-2019 11:22
Hi @MarreFitbit @I tried all those options but nothing works. It is not able to connect to Bluetooth so I was not able to change the clock face or sync.
it does seem like getting restarted (when connected to power)with half white line showing couple of seconds and then a smiley face comes then the screen goes blank again.
11-04-2019 11:30 - edited 09-25-2024 13:12
Hello there @ApiFit, thanks for following the tips and recommendations I provided above.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know. 😉
05-12-2020 13:14
05-12-2020 13:14
Thank you! Worked!!
01-20-2021 19:44
01-20-2021 19:44
Make sure sleep mode is off. I just figured this out after weeks. Lol
