01-22-2019
18:35
13:05
01-22-2019
18:35
13:05
I was having an issue where my Charge 3 wouldn’t sync to my Galaxy S8 anymore and then suddenly today the screen froze. It is stuck on the number of floors. Plugging into charger and holding in button won’t restart it. Don’t know what happened or how to fix.
12-14-2019 04:47
12-14-2019 04:47
Changing the clock face worked! I tried the long-press restart first, and it didn't work. Then I tried the clock, and that did it, so thank you!
Best Answer12-14-2019 04:53
12-14-2019 04:53
This use to happen with my Inspire HR. What worked for me was shutting the bluetooth off, go into settings> apps> Fitbit app...then click on force stop. Go and turn your bluetooth back on, and open up the fitbit app, and sync it.
Best Answer12-14-2019 07:33
12-14-2019 07:33
Best Answer12-15-2019 13:54
12-15-2019 13:54
Best Answer05-12-2020 09:15
05-12-2020 09:15
After much frustration and coming close to throwing my Charge 3 out, I decided to do one last thing...and success, I got the smiley face and the screen is back working and it's synching.
I was using the charging cable plugged into my laptop. Wouldn't reset screen.
Then moved charging cable to desktop PC. Same problem. Nothing happening. Screen frozen so couldn't get four digit code. Then plugged it into wall socket...instantly worked, reset no problem. Worth a try if nothing else is working!
Dissatisfied with how fickle Charge 3 is. My son got his Whoop strap a month before I got this and has not had any issues. I've had the frozen screen problem a few times in just three months.
Best Answer05-12-2020 15:54
05-12-2020 15:54
I know the frustration in the frozen screen. If it keeps happening more than once, then you should call the Fitbit company and tell them. That's my best advice to you. Even the best gadgets have errors in them.
Best Answer06-22-2020 13:24
06-22-2020 13:24
Hi -
My Charge 3 keeps becoming completely unresponsive - black screen, unable to sync or charge, no vibration or indication when i press the button.
I have tried both the 8-second reboot, and the 15 second reboot. The 15 second reboot seems to work about half the time (I've tried it about 10 times) - but "normal operation" either doesnt return - I get to the smiley face stage and then it goes off again, or it starts up, but then goes unresponsive again a few seconds later - I usually don't even have enough time to put it back on my wrist.
Thoughts?
Best Answer06-22-2020 19:25
06-22-2020 19:25
