10-09-2018
11:17
15:47
10-09-2018
11:17
15:47
I just received my tracker about an hour ago. I've turned it on and synced it and I've got a solid white line across the middle of the screen! Is there any way of fixing this or is it going to have to be sent back for replacement?
A reboot didn't help...
04-05-2021 00:53
04-05-2021 00:53
04-05-2021 02:54
04-05-2021 02:54
04-05-2021
05:32
06:34
WilsonFitbit
04-05-2021
05:32
06:34
WilsonFitbit
No fix. you have to get fitbit to replace your watch. They replaced mine,
but I think I was still under one year. Anyway, this will probably be my
last fitbit as I couldn't get the same color i had and the battery on this
new one is weak. Good luck
05-02-2021 04:51
05-02-2021 04:51
i have the same problem with my charge 3. How do I get a replacement if we are not able to fix it? Please help.
05-02-2021 06:00
05-02-2021 06:00
05-02-2021 08:54
05-02-2021 08:54
05-07-2021 05:48
05-07-2021 05:48
Hello everyone. @JanieSam Welcome to the community forums. @tucker56, @orangutansaver It's great to see you around and thanks for your input.
If the suggested troubleshooting steps in this thread haven't helped, my best recommendation is that you please reach out to our Support Team for further assistance. Note that you can explain the situation and the troubleshooting steps you've followed, this way they can assist you from there.
Also, note that you can contact them through chat or over the phone and you can click here to get connected. On a side note, replacement devices are provided for products within the warranty period. If your original Charge 3 is no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information about our warranty policy, please check:
https://www.fitbit.com/global/us/legal/returns-and-warranty.
See you around.
05-29-2021 20:49
05-29-2021 20:49
My fitbit charge 3 also having exactly the same issue. Reboot failed to resolve the issue. I’m so disappointed!
06-07-2021 07:23
06-07-2021 07:23
Hello @WhamMhey. Welcome to the community forums.
I'm sorry for the inconvenience and thank you for the steps you've tried prior to posting. I recommend contacting our Support Team for further assistance. As mentioned on a post above, you can contact them through chat or over the phone and you can click here to get connected. Make sure to explain the situation and the troubleshooting steps you've followed, this way they can assist you from there.
On a side note, this thread is now closed. If you still have any questions or inquiries, please post them in a new thread.
See you around.
