10-09-2018
11:17
15:47
10-09-2018
11:17
15:47
I just received my tracker about an hour ago. I've turned it on and synced it and I've got a solid white line across the middle of the screen! Is there any way of fixing this or is it going to have to be sent back for replacement?
A reboot didn't help...
10-28-2018 01:07
10-28-2018 01:07
10-28-2018 04:30
10-28-2018 04:30
10-28-2018 20:01
10-28-2018 20:01
Hope that happens to mine!!!
10-30-2018 18:43
10-30-2018 18:43
Thank you for the update @Nan-001, it's great to know the replacement Charge 3 is working properly for you.
I'm sorry to see that you had to return your devices due to this inconvenience @CCannata, but I hope it's possible for you to return to the Fitbit family in the future.
That's great news @Alyson57, thank you for this update as well!
@Crimsomlady9, while sending your information to the Customer Support team I've been informed that you already have a case created with them and they're providing you assistance with this. You should be getting a reply soon.
Keep us posted on the outcome.
10-30-2018 18:46
10-30-2018 18:46
11-01-2018
07:20
07:59
AlejandraFitbit
11-01-2018
07:20
07:59
AlejandraFitbit
Just received my replacement Fitbit Charge 3 from Fitbit yesterday after they sent the device through snail mail. Finally got a device whose screen turns on. Now less than 24 hours later there is a line on the display and what appears to be a dead pixel. Any thoughts?
11-01-2018 07:26
11-01-2018 07:26
Yes! Restart it several times and if this doesnt fix it (doubt it will but give it a go anyway), contact Support again. I know it is a pain but bite the bullet and contact them.
Helen | Western Australia
11-02-2018 08:01
11-02-2018 08:01
It's great to see you here @YardleyFFL and @NellyG thanks for stopping by.
I appreciate the image provided and would like to know if the instructions provided by our friend worked? Are you still having problems with your tracker's display?
Hope to hear from you soon.
11-02-2018 14:37
11-02-2018 14:37
Yes I am still having problems. After wasting more of my personal time with customer service dealing with this defective device I’m being told that they would like me to package it up (for a 2nd time) and they will send me a replacement (which would be my 3rd Charge 3). I originally received the Charge 3 on October 7 and it’s almost 1 month later and I don’t have a functioning product yet they have my money!
11-03-2018 10:45
11-03-2018 10:45
THIS is exactly what I am seeing on mine. I just got it an hour ago. Is there anyway to fix it?
Thanks!
11-03-2018 12:44
11-03-2018 12:44
11-03-2018 12:53
11-03-2018 12:53
11-03-2018 16:10
11-03-2018 16:10
11-04-2018 03:06
11-04-2018 03:06
Thanks for the information @YardleyFFL.
It's great to know that you contacted our support team and were offered a replacement. Your patience in this is much appreciated and I hope you don't experience any issue with your new tracker.
Let me know if you need anything else.
11-04-2018 08:38
11-04-2018 08:38
Hi. Just opened and set up my Fitbit Charge 3 yesterday. It works completely fine but I have a white line across my screen that won’t go away. I tried resetting it but nothing seems to work. Any help is much appreciated. Thanks!
11-05-2018 19:14
11-05-2018 19:14
I have the exact same issue. I've had my Charge 3 for ten days now. It was perfect for the first nine days... and then yesterday a white line showed up with the word "alignment" across the screen right above the line. It happened shortly after someone left a voicemail message for me, and I figured it might be related to that / some kind of notification gone wrong.
Anyway, the "alignment" text disappeared a couple hours later, but I still have the solid white line across the entire width of the screen. I've done several restarts, ran a firmware update, etc., but the line is still there.
11-05-2018 20:35
11-05-2018 20:35
11-06-2018 11:03
11-06-2018 11:03
Same problem with my new sim I bought today!!
White line across the screen!!
11-06-2018 11:05
11-06-2018 11:05
A white line across your screen probably means that your Fitbit is updateing just leave it alone for like 30 minutes.
11-06-2018 11:08
