02-03-2020
09:27
15:05
02-03-2020
09:27
15:05
Hi. My Fitbit screen has gone all fuzzy and I am unable to read any of the data. I have tired resets but it isn’t working. Could anyone provide any assistance on this? Thanks
02-03-2020 11:06
02-03-2020 11:06
Try a Long Restart:
CHARGE 3 LONG RESTART
Connect the device to the charging cable.
While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
The device turns off.
The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
Remove the device from the charging cable. The device shuts down.
Important: Plug the device into the charging cable again.
Best Answer02-03-2020 11:28 - edited 04-29-2024 05:57
Hi there @ChatwinL, welcome to the Community Forums. Thanks for the details provided.
As my friend @cbwilsha recommended, please perform a long restart on your Charge 3 by following the steps he provided.
In case that the restart doesn't work, please check in your Fitbit app if your Charge 3 is still syncing. If so,change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Best Answer02-03-2020 11:29
02-03-2020 11:29
Hi. I did try all of these. I have now spoken with web chat and a new device has been issued. Thank you for the response
02-03-2020 11:31 - edited 04-29-2024 05:56
Thanks for getting back @ChatwinL and letting me know the outcome of the steps recommended. I'm glad to hear that our Support Team has helped you with this. 😉
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer08-23-2020 17:49
08-23-2020 17:49
I love my Fitbit Charge 3, but it has broken my heart. Same thing happened to me. Very hard to see - fuzzy screen. I charged it, tried a reset, tried a long restart, and changed the clock face. Nothing worked. I don't want to have to buy an iWatch, but will be forced to if Fitbit doesn't help me. Please help!
Best Answer08-23-2021 11:19
08-23-2021 11:19
Mine is also not working! Please help fit bit
06:38
07:33
08-25-2021
06:38
07:33
Hello everyone. @Smileygal411 Welcome to the community forums.
I'm sorry for any inconvenience. If the suggested tips in this thread didn't help, I'd recommend reaching out to our Support Team for further assistance. Note that you can get in touch with them through chat or over the phone, but phone wait times have been a little bit longer than normal. Click here to get connected.
Please make sure to provide a brief explanation of the inconvenience and mention the troubleshooting steps you've followed, this way they can assist you from there.
