07-05-2021
01:12
04:21
WilsonFitbit
07-05-2021
01:12
04:21
WilsonFitbit
My readout just went to a lower brilliance , also the Fitbit does not vibrate now when my iPhone rings ,as I am in a noisy environment and the wrist vibrating is better than the phone & the phone ring , I am 77 & a ``little bit`` deaf also ! haha
Ashley My grandson said the ``DND`` (above the Moon Icon) may be Do Not Disturb ??
Moderator edit: subject for clarity/label
07-05-2021 04:19
07-05-2021 04:19
Hello @SunsetRunner. Welcome to the community forums.
I'm sorry for any inconvenience and thank you for the detailed information. As your grandson mentioned, I recommend making sure that your Charge 3 hasn't gone into sleep or DND mode. When any of these settings are activated:
To change this, press and hold the button, and swipe left to access the quick settings screen. Tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it. For more information, see How do I navigate my Fitbit device?
If this is not the case, I'd recommend performing a restart to your Charge 3 by following the instructions here. For the notifications, I also recommend taking a look at this help article if the notifications still don't work after disabling any of the settings above.
Hope this helps.
07-05-2021 04:19
07-05-2021 04:19
Hope this helps.
08-03-2021 13:07
08-03-2021 13:07
HI my Fitbit charge 3 is extremely dim. I tried from another post to power done, get the progress line, and plug back in. but screen is still dim, can't see anything to determine if dnd is on or even to brighten the screen as i've done in the past. since my fitbit 3 charge is attached to my account, can i do it through the website?
08-12-2021 07:04
08-12-2021 07:04
Hello @Tvdrosos. Welcome to the community forums!
Thank you very much for the information and for the troubleshooting steps you've tried prior to posting. Currently, there isn't an available option to adjust the brightness of your Charge 3 through the website, nevertheless, I was able to see that you have reached out to our Support Team and they have provided information and assistance. If you still have additional questions or inquiries about the outcome of your case, I recommend replying back to them and they will be more than glad to continue assisting you.
See you around.
