10-21-2019
12:39
10:40
10-21-2019
12:39
10:40
The screen on my fitbit charge 3 is partly faded. It is fully charged and just started fading. Can anyone help?
10-30-2019 07:15 - edited 10-30-2019 07:16
Hello @Abitfit72, thanks for getting back and letting me know that you already received your replacement.
Please try charging your Charge 3 for at least 1 and then restart it by following these steps. If the restart doesn't work and the display is still not turning on even after the recommended steps. Please take a look at the help article: Why isn't my Fitbit device's battery charging?
Once the tracker is turn on, set it up by following the steps below:
1. Remove your old Charge 3 from the Bluetooth settings on your phone.
2.Turn off other Bluetooth connections when not in use.
3. Plug it into the charging cable and open the Fitbit app.
Let me know if you need further assistance, I'll be around.
Best Answer10-22-2019 07:39
10-22-2019 07:39
Hi there @Abitfit72, welcome on board. Thanks for making sure that your Charge 3 is fully charged.
If your Charge 3 display is fading, I'd recommend restarting your device by following the steps below:
Give this a shot and let us know the outcome.
10-22-2019 08:15
10-22-2019 08:15
Hi.
I tried this and it us still faded. Any other ideas?
10-22-2019 11:35 - edited 10-22-2019 11:36
Hi there @Abitfit72, thanks for following the suggestions I recommended and for the photo attached.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Best Answer10-28-2019 13:08
10-28-2019 13:08
I now have a new fitbit but I cant get that to charge. It doesn't vibrate when I connect to the charger. I have tested the socket in others but no change. I have swapped it with my old one and can feel the vibration on that one. Please help!
Best Answer10-29-2019 09:52
10-29-2019 09:52
Hello there @Abitfit72. I've confirmed that our Support Team has been working with you after I created the support case for you. 😉 Keep an eye on your inbox for updates about your new tracker.
Let me know if there's anything else I may do to help you in the meantime.
Best Answer10-29-2019 13:26
10-29-2019 13:26
Hi
I have my new tracker but I cant switch it on and it wont charge.
Best Answer10-30-2019 07:15 - edited 10-30-2019 07:16
Best Answer01-08-2020 08:03
01-08-2020 08:03
I am also experiencing the same issue and its getting harder to read the display.
01-08-2020 12:59
01-08-2020 12:59
Hi
Hopefully customer service will see this and help you. If not, report it to customer service and attach photos so they can see. They may want to have a live chat. If you got through your app on contact us it may be quicker.
Good luck.
Best Answer01-09-2020 12:37
01-09-2020 12:37
Hi there @SM15TRY, welcome here. Thanks for reporting what's happening with your Charge 3's display.
In order to sort this out, I'd recommend restarting your Charge 3 by following the steps provided in the help article: How do I restart my Fitbit device?
Thanks for your help and suggestion @Abitfit72. Indeed, I'll be more than glad to forward the situation to our Support Team in case the steps recommended don't work. 😉
I'm looking forward to your response, keep me posted.
Best Answer01-10-2020 12:31
01-10-2020 12:31
01-10-2020 14:43
01-10-2020 14:43
Hello there @SM15TRY, thanks for getting back and letting me know that you've tried the restart recommended.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
I'll be around if you have any questions present.
Best Answer03-26-2020 17:59
03-26-2020 17:59
My screen also started fading just after one year. I contacted Fitbit support center. This is the response I got - Same problem as yours
Response from Fit Bit on 26-MAR2020
After checking in our system, we are able to see that the warranty of your Charge 3 started back on February 12th 2019 and ended on February 12th 2020. Although this isn’t eligible for replacement since the warranty is already expired, we want to keep you in the Fitbit family and working toward your goals. Please accept a discount toward the purchase of any one of the devices on fitbit.com
My request to the public :
Fitbit sold defective product and offering 25% discount after the warranty. Shame on Fitbit company. If you search in the google so many people gave a complaint that the screen has problem, so Fitbit know that the product has defect instead of fixing the defect they are selling defective product to the customer and after one-year Fitbit offering 25% discount. I am not going to buy their products any more.
Shame on Fitbit selling the defect products to the customer. My request to the public please do not buy their products. You will suffer one day. Please convey to your friends and family members not to buy Fitbit products.
04-12-2020 04:36
04-12-2020 04:36
Hi, I have the same issue
I wear it every day, for every run, every hike, every workout. But it's been a pain recently I cannot see the screen settings while want to set as a new run. I then come back did exactly what you asked reset. Same problem. I looked deeper , dome fonts are brighter than other letters , numbers display.
Is it normal? Same frustration as others that I no longer know the stats of running
06-19-2020 09:45
06-19-2020 09:45
I'm having the same issue. This fitbit is already a replacement because my first one randomly stopped syncing with my phone. Now I can barely read the screen. I've tried re-starting and it's fully charged. I tried to take a picture and you can't even tell it's on. It's getting worse by the day. & I can't get notifications from my phone - I'm opted in.
07-12-2020 19:16
07-12-2020 19:16
Hello!
I have a faded face to my Charge 3 as well. I have tried the four steps listed here as well as the other suggestion to hold side button for 8 counts after full charge. I have not had my device in water, and keep it wiped down. I have had difficulty reading the face of the device for a month.
Thank you in advance.
07-28-2020 01:27
07-28-2020 01:27
hi
my screen started to go dark about a month ago. I couldn’t see screen outside in daylight. Now I have I light streak down the middle of my screen and find it hard to swipe to other screens. Have restarted it several times using both methods suggested with no change. it charges fine. Don’t know how to attach a photo.
08-05-2020 10:00 - edited 08-05-2020 10:11
I am having the same issue!! First it faded, and I couldn't see it outside at all. Now, almost completely gone even when I am inside with better lighting. I changed the font and brightness...no help!
08-05-2020 10:16
08-05-2020 10:16
