08-20-2022
13:43
17:02
LizzyFitbit
08-20-2022
13:43
17:02
LizzyFitbit
I can’t see the white data that is displayed on my Fitbit. I want to make it brighter but I can’t see anything so I don’t know if I’m swiping correctly to make it brighter. Help please. I have a Fitbit 3.
Moderator Edit: Clarified subject and updated label
08-23-2022 06:18
08-23-2022 06:18
Hello again @Katdav16
Your not changing the clock face directly on your Charge 3. Your changing by going through the Fitbit App.
Open the Fitbit App, tap your profile picture then scroll down and tap Charge 3. Now tap Gallery then tap clock tab. Browse the available clock faces. Tap the clock face you want then tap Install.
If the problem persist I’d recommend contacting Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US
😉 I hope this helps
08-20-2022 14:02
08-20-2022 14:02
Hello @BooBoo2014
I wonder if you accidentally put your screen brightness on dim. To change the brightness to dim, normal or max you need to swipe left two times from your clock face then tap the settings gear wheel. Next tap display then chose which settings you prefer.
Here is a YouTube video that may help guide you since your screen is too dim to see: https://m.youtube.com/watch?v=4dzr9PVKdRw
😃 Please let me know if this helps and provides you with an answer to your screen being dim.
08-22-2022 17:51
08-22-2022 17:51
That's great except I can't see the settings gear. Screen is black even in a dark room.
Best Answer08-23-2022 05:23
08-23-2022 05:23
Hello @Katdav16
If your screen is completely black have you tried restarting your Charge 3. Here’s how it’s properly done: https://help.fitbit.com/articles/en_US/Help_article/1186.htm
If restarting your Charge 3 fails to address the issue try changing the clock face going through the Fitbit App. Sometimes changing the clock face will address screen issues: https://help.fitbit.com/articles/en_US/Help_article/2311.htm
😃 Please let me know if this helped
Best Answer08-23-2022 05:44
08-23-2022 05:44
Best Answer08-23-2022 06:18
08-23-2022 06:18
😉 I hope this helps
10-31-2022 00:14
10-31-2022 00:14
Just go to settings/brightness and select brightness you want Dim/Normal/Auto. It defaults to dim.
Regards,
Will
