Charge 3 screen not turning on
My charge 3 seems to be working per the app but I have no screen display. The HR light is on when I wear it. Not sure whats going on TIA!
1 REPLY 1
Welcome to the Fitbit Community, @Stone88.
I am sorry to hear that the screen on your Charge 3 is not working. Thank you for letting me know that the tracker seems to be working per the app and the heart late light is on. I understand how you are feeling and I am here to help you. I recommend trying the following:
  1. Restart the device: How do I restart my Fitbit device?
  2. Change a clock face: How do I change the clock face on my Fitbit device?
  3. Long restart:
  • Connect the device to the charging cable.
  • While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  • The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration
  • The device turns off.
  • The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  • Remove the device from the charging cable. The device shuts down.
  • Important: Plug the device into the charging cable again.
Let me know how it goes, I'll be around.
